question about vacuum pump!
Old Jan 15, 2013 | 02:05 AM
draboo's Avatar
draboo
Now the alternator dilemma is solved, it's vacuum pump noise!
I have the dreaded "only blows thru defroster" situation going on. I checked the pump today, and it's runs constantly. I turn on the key, and it sits there and buzzes. I m guessing it's shot. The truck has 160K miles on it.
I ve never heard it make any sort of noise before till this morning.
Is there a procedure for checking this out, or does the situation warrant another pump, considering it's constant state of activity.
Thanks once again,eh?
Brad
Old Jan 15, 2013 | 03:02 AM
Yahiko's Avatar
Yahiko
You know that they suck when they are good and SUCK when they go bad.
The pump may be good.
Pull the line off it and plug it and see if it stops running
after a bit. You need to do that till you find the leak or a bad pump.
You can rent one of the little hand ones with a gauge at most parts
stores and with that you can track down leaks.
Sean
Old Jan 16, 2013 | 03:34 PM
draboo's Avatar
draboo
Thanks for the info,Yahiko! I blocked off the main line coming off the pump and it did shut off immeadiatly, so I m searching for the leak..wife is complaining about no heat on the floor.
I found the diagrams on this website helpful. I searched till I was crosseyed for a vacuum diagram for my truck last night and finally found these this morning!
Ford F350 Pickup Super Cab need vacuum diagram for 05 f350 - JustAnswer
Old Jan 16, 2013 | 05:51 PM
Yahiko's Avatar
Yahiko
Did you check the ESOF system ? That is one of the things to look
at when the heat is only coming out the defroster.
Sean
Old Jan 16, 2013 | 09:14 PM
draboo's Avatar
draboo
At first, I thought it was the canister. After some trial and error diagnosis, I have concluded that it is,indeed, the ESOF relay. I bypassed it ( I have manual lockout hubs), plus I eliminated the canister. The only thing hooked up to the pump is the heater control system. The heater controls work fine, tho I didn't try the AC yet.
I do have one question since I bypassed the ESOF relay thing: Is the transfer case actuation vacuum operated like the hubs were? If so, I ll be needing to get another vacuum relay.
Old Jan 16, 2013 | 09:29 PM
BLADE35's Avatar
BLADE35
Check the Valve in the Heater Coolant supply line
Since you just replaced the ALternator this Line Could have came Off the Valve thats Circled in RED in this picture
See the Grey Vac Line to valve
Old Jan 16, 2013 | 09:36 PM
draboo's Avatar
draboo
I m awaiting a new pulley for the alternator. Haven't touched it as of yet. I did check that vacuum fitting and it is connected.
Walleye Hunter
Apr 19, 2014 10:54 AM
endobear
17
Apr 8, 2014 09:49 PM
cak301
May 8, 2010 03:13 PM
greedy737
Mar 23, 2008 08:44 PM
resonance530
Jul 26, 2006 09:23 AM
