starter??
Old Jan 12, 2013 | 04:23 PM
sarnott140's Avatar
sarnott140
starter??
06, 190K. went to start my truck yesterday and the first couple times i tried it just gave one click, started on 3rd try. then today same thing. temperature dropped yesterday to about -20*C and remaims about the same today, would that have something to do with it?? Battery connections good. I'm thinking starter solenoid which i believe is built into the starter, am i right??
Old Jan 12, 2013 | 04:34 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Right, the solenoid is mounted to the starter.
If you're sure the cables and connections are clean then most likely you have a failing solenoid or weak batteries.
Both can be tested at any parts store.
Josh
Old Jan 12, 2013 | 04:56 PM
sarnott140's Avatar
sarnott140
do you know if i can buy just the solenoid itself?? also where exactly is the starter?
Old Jan 12, 2013 | 05:00 PM
Bullitt390's Avatar
Bullitt390
There was a discussion about a week ago on this and the conclusion was no, you cannot buy just the solenoid (easily anyways) but you can get a rebuild kit that includes new contacts etc.
Josh
Old Jan 12, 2013 | 05:02 PM
Bullitt390's Avatar
Bullitt390
Here is the thread:
https://www.ford-trucks.com/forums/1...-and-6-0s.html
Josh
Old Jan 12, 2013 | 06:11 PM
sarnott140's Avatar
sarnott140
if it was my batteries, it wouldnt click just once, then start on the 3rd or 4th try...or would it?? they're 3 years old so i wouldnt think theyd be bad yet, but it does get real cold in the winter
Old Jan 12, 2013 | 06:17 PM
Bullitt390's Avatar
Bullitt390
Those symptoms can easily be dead batteries, but most likely I would say bad solenoid.
I would have the batteries load tested (seperately) and the starter. Also verify condition of the cables.
Josh
Old Jan 12, 2013 | 06:41 PM
sarnott140's Avatar
sarnott140
my scangauge shows the batteries at about 10volts with the key on and glowplugs on when its cold
Old Jan 12, 2013 | 06:49 PM
Bullitt390's Avatar
Bullitt390
With the GP light on or while trying to crank?
I see about 11.0 volts with initial key on with GP cycling and the injectors buzzing, after the buzzing it is about 11.2 volts or so.
That is at the OBD port using DashBoss.
Also those numbers are at about 20-25 degree fahrenheit.
Josh
Old Jan 12, 2013 | 06:55 PM
sarnott140's Avatar
sarnott140
it reads about 10.2-10.5 with the gp light on and injectors buzzing, that does seem low i geuss
Old Jan 12, 2013 | 06:57 PM
Bullitt390's Avatar
Bullitt390
And check out this video on repairing a solenoid.
The main part starts at about 55 seconds...
<iframe width="420" height="315" src="http://www.youtube.com/embed/a4-Jspd71IU" frameborder="0" allowfullscreen></iframe>
Josh
Old Jan 12, 2013 | 06:59 PM
Bullitt390's Avatar
Bullitt390
Check out this video for repairing a solenoid... main part begins about 2:58 or so...
Josh
Old Jan 12, 2013 | 07:00 PM
Bullitt390's Avatar
Bullitt390
Looks to be that way...
Josh
Old Jan 12, 2013 | 09:44 PM
mhoefer's Avatar
mhoefer
Load test them batteries asap. They need to be charged up individually first to properly test them. Should be at-least 11.x on GPS, no matter how cold. Your starter may still be weak but you are definitely being hard on FICM with those lower voltages, it has to make up with increased current which melts them bad......
blacklab1
Dec 17, 2018 06:46 PM
MackGuy
Jan 15, 2013 06:44 AM
lamenytro
Jul 3, 2011 08:51 AM
Ford79
May 26, 2011 07:48 PM
rich gill
Aug 28, 2010 02:57 PM
