Starter just clicks
Old Dec 16, 2018 | 04:03 PM
blacklab1's Avatar
blacklab1
Starter just clicks
95 f-159 5.0 auto. Having a problem with starter, if the truck sits for awhile all I get is the solenoid clicking.
The only way I can start it is to crawl under and short the starter solenoid.
Doesn't do it all the time, any suggestions, I'm tired of crawling under in the dirt
Old Dec 16, 2018 | 06:10 PM
88n94's Avatar
88n94
My first guess would be the small wire that runs from the fender mounted solenoid to the solenoid on top of the starter. More likely the connections on the ends of that small wire.
Old Dec 17, 2018 | 01:02 PM
blacklab1's Avatar
blacklab1
I was going to clean all the contacts today. Truck started fine but when I shut it off now it's a no go.
When I cross the contacts on the starter solenoid like I have been doing, all I get is clicks and sparks.
Is the starter shot?
Old Dec 17, 2018 | 01:08 PM
Glaser67's Avatar
Glaser67
Wouldn't be a bad idea to clean all contacts, from the battery terminals, to the solenoid, to the starter, including engine grounds. If your still having problems and suspect the starter, yank it and take it to autozone, the diagnose for free.
Old Dec 17, 2018 | 01:29 PM
blacklab1's Avatar
blacklab1
There is power to the starter solenoid, I can feel it click like it is trying to engage.
Old Dec 17, 2018 | 02:40 PM
evan_nugget's Avatar
evan_nugget
I would first do what Glaser said - clean every electrical/ground connection thoroughly. Next, take a test light and make sure you have constant 12V to the battery side of the starter solenoid. Next check if the test light lights up the other side of the solenoid when the key is turned to the START position. If that checks out then the solenoid is good, and it may be a starter issue.
I was chasing down the same issue with my 1988 Bronco - turning the key would just get a big CLICK from the solenoid and it wouldn't turn over. I figured it was the starter but the above procedure saved me from buying a new parts store starter that probably would have failed in a few years... Turned out I wasn't getting power to the starter side of the solenoid - replaced it and it cranks over strong.
Old Dec 17, 2018 | 02:43 PM
evan_nugget
Duplicate post--------------------------
Old Dec 17, 2018 | 04:10 PM
blacklab1's Avatar
blacklab1
What is driving me nuts is it started 4 or 5 times this morning. I was just going to move it to the ramps to get under and it won't go. Other times I could cross the poles on the starter solenoid and it would go.
It's now sitting in a puddle of wet snow, I'm worried it may not even burn.
Old Dec 17, 2018 | 06:46 PM
blacklab1's Avatar
blacklab1
Thanks for all the suggestions. I finally bit the bullet and layed in the slush and pulled the starter.
The main power wire was loose, couldn't tell till I pulled the starter.
Works now!
anadiller
18
Sep 17, 2017 09:31 PM
va150
Jun 28, 2012 10:09 PM
lamenytro
Jul 3, 2011 08:51 AM
savag
Feb 19, 2011 03:11 PM
rich gill
Aug 28, 2010 02:57 PM
