Shocks?
Old May 27, 2003 | 05:48 PM
brussell's Avatar
brussell
Shocks?
Have a 98 EB with LLS wondering if different shocks would "tighten up" the ride. The thing rocks like crazy pulling into my driveway. Any suggestions on type?
Thanks!
Brad
Old May 29, 2003 | 10:06 AM
brussell's Avatar
brussell
Shocks?
Anyone?
Old May 29, 2003 | 10:59 AM
Bob Ayers's Avatar
Bob Ayers
Shocks?
I've had very good luck with Bilsteins!!
Old May 29, 2003 | 11:02 AM
buzzard's Avatar
buzzard
Shocks?
Ranchos, Bilsteins and Edelbrocks seem to be the favorites, although the Edelbrocks have been known to fail prematurely.
I'm a Rancho guy personally.
Old May 29, 2003 | 11:15 AM
brussell's Avatar
brussell
Shocks?
Thanks!
Any suggestions on where to find the Bilstiens?
Brad
Old May 29, 2003 | 11:41 AM
2000Expy's Avatar
2000Expy
Thumbs up Shocks?
I ordered mine from Shox.com for $65 ea including shipping. I've been pretty satisfied with them. They are a bit firmer than OEM, but much more control.
Old May 29, 2003 | 01:26 PM
tsdrallyer's Avatar
tsdrallyer
Shocks?
You won't be sorry if you get the HD Bilsteins. Very good control on small or very large (catching air) bumps have 80K miles on my set with 4 corner air and they are still like new. They are guaranteed to last as long as your vehicle.
Hope this helps.
Old May 29, 2003 | 02:48 PM
bigbert's Avatar
bigbert
Shocks?
My 98 EXPY with LLS has the same issue.
Can someone explain what impact the LLS has on the replacement shocks?
Will any shock due or does the LLS make it require something special?
Old May 29, 2003 | 05:51 PM
brussell's Avatar
brussell
Shocks?
So I place the order with Shox.com and then Chris calls me back and tell me that Bilstien doesn't make them for the front with LLS and he can't find anyone who does. Anybody had any luck with front shocks?
Thanks!
Brad
Old May 30, 2003 | 09:12 AM
2000Expy's Avatar
2000Expy
Question Shocks?
Isn't it true that you only have the LLS air suspension in the rear? Why would you need a different type of shock in the front from what I have? I would check that. BTW, these shocks are packaged individually, so when they have a set (020. Bilstein shocks) on their website that is not a four-pack or anything. They could sell you the fronts and then the rears (0201. Bilstein shocks) for LLS.
Old May 30, 2003 | 09:49 AM
bigbert's Avatar
bigbert
Shocks?
Actually it is four corner load leveling suspenson and the issue appears to be with the front shocks not the rears.
The rears are standard.....
The fronts are very expensive and hard to find....
Old May 30, 2003 | 10:13 AM
brussell's Avatar
brussell
Shocks?
tsdrallyer - maybe you can help us out here? You seem to have found a way arround the issue. If I'm correct you say that you have the LLS and Bilstiens all the way arround. How did you do it?
Thanks!
Brad
brussell's Avatar
brussell
Shocks?
Thanks!
Brad
Bsherry
Escape & Escape Hybrid
Oct 23, 2013 07:45 AM
Chuck_Sloggett
Aug 31, 2007 11:28 PM
warmdye
Jul 17, 2002 06:07 PM
DrFord
Jun 12, 2002 09:24 PM
honney
1978 - 1996 Big Bronco
Nov 16, 2001 10:27 AM
