e street heads
Old Jan 12, 2013 | 12:13 AM
gyrhed's Avatar
gyrhed
e street heads
A buddy came over to the house tonight seems he fell into a set of Eldebrock estreet heads in parts of a trade he worked out and will almost give them to me for my 351W I am building for my EB. I got all exited went on the eldbrock website and it clearly states that they are not compatible with a hydraulis roller cam.
I am going to call eldebrock monday but thought maybe someone here would know why and is there something i could do to use them?
Old Jan 12, 2013 | 12:30 AM
Beanscoot's Avatar
Beanscoot
Are these the heads:
Edelbrock.com - Cylinder Heads - Ford - Small Block - E-Street 170 ?
I see the disclaimer about hydraulic roller camshafts. Perhaps it's because the lifters are taller, and they impinge on the undersides of the heads at full camshaft lobe lift.
Old Jan 12, 2013 | 10:51 AM
Conanski's Avatar
Conanski
It's hard to believe Edelbrock would make a head that's not compatable with the vast majority of engines it would potentially be installed on.. the roller cammed 5.0HO, so there has to be more to the story.
Old Jan 12, 2013 | 11:08 AM
gyrhed's Avatar
gyrhed
My thoughts exactly
Maybe its an rpm/lift/float thing and they just dont want to publish a limitatation knowing people will ignore it.
Old Jan 12, 2013 | 01:54 PM
Conanski's Avatar
Conanski
A little searching over on the Mustang forums turned up all sorts of interesting threads on these heads. Apparently they'll work fine with stock roller cams or even relatively mild aftermarket cams... that is until the cheap as dirt supplied springs or retainers begin to break at as little as 500miles. Edelbrock says.. "what did you expect for $900 heads" and there are even engine builders agreeing with that assesment, but to me that's a load of garbage so it looks like these things should be avoided at all costs.
Old Jan 12, 2013 | 06:35 PM
gyrhed's Avatar
gyrhed
kind of silly isnt it? Not like eldbrock cant put good springs on it. they have performer heads that work with roller cams, there still something fishy about these heads huh?
Old Jan 14, 2013 | 08:49 PM
gyrhed's Avatar
gyrhed
I looked on the eldebrock website and they list hydraulic roller cams for use with these heads as part of their power packages but only when used on the SBC.
nstueve
Feb 2, 2010 08:25 PM
clgreer
May 17, 2009 02:30 PM
projectbad78
13
Apr 9, 2009 10:38 AM
BaronVonAutomatc
15
Mar 4, 2007 10:35 AM
fatfenders
Feb 12, 2006 07:25 PM
