Crankshaft install
Old Jan 11, 2013 | 09:50 PM
ms92069's Avatar
ms92069
Crankshaft install
Does anyone have a handy trick to time the crank and cam together without the special tool they want you to use? It looks to me like you could just make sure the cam timing mark was 180 degrees away from the crank instead of right on it it would work. But I don't want to do it twice.
Old Jan 11, 2013 | 10:36 PM
Yahiko's Avatar
Yahiko
This tool ?
OTC 303-772 That Ebay seller wants a mint for it.
OTC 303 772 Camshaft Alignment Tool Ford 6 4 Diesel and 6 0 Diesel | eBay
I have it sitting right here in my hands. It's very heavy looks like 1/4" steel .
I think you could make one if you wanted to.
Sean
Old Jan 11, 2013 | 10:43 PM
Papa Tiger's Avatar
Papa Tiger
Magnify the picture X200 to get your basic measurements. Pick up a Stanley framing square and cut it down, drill the hole and cut the notch with a dremmel tool, leave the extra length to put the 3/4 inch 90 degree drop down bends in it.
Old Jan 11, 2013 | 11:10 PM
ms92069's Avatar
ms92069
yep
That is the tool in question. What pic?
Old Jan 11, 2013 | 11:13 PM
Yahiko's Avatar
Yahiko
Here is a second view
It's 3 flat sections and 2 pins
Sean
Old Jan 11, 2013 | 11:25 PM
Yahiko's Avatar
Yahiko
I just thought of something else.
Your going to need the other two tools to install
the crank seals.
Crankshaft Rear Seal Wear Ring Installer 4 5L 6 0L 6 4L 303 770 Alternative | eBay
Crankshaft Rear Seal & Wear Ring Installer
Crankshaft Front Seal and Wear Ring Installer Set 6 0L 303 761 Alternative | eBay
Sean
Old Jan 12, 2013 | 04:56 AM
ul37's Avatar
ul37
there is a hole in the cam gear that lines up with a hole in the block using a number 2 philips screw driver, than place crank into the block with the dowel pin lined up with the screwdriver.if the block is upside down(crank facing up) the dowl on the crank willbe located at 6 O'clock.real simple done this countles times.
Old Jan 12, 2013 | 10:06 AM
CPB1's Avatar
CPB1
the crank seals.
Sean
Great find, thanks for that. I looked all over for this tool. Well actually just in OTC tools. It looks like you can get both installers for under $500.
Chuck
Old Jan 12, 2013 | 10:25 AM
ms92069's Avatar
ms92069
excellent
Thanks so much that is just what I needed. Problem solved. Now to figure a way around the seal installers....But first I need to find a source for some rings today in so cal.
mattdoc88
Nov 20, 2017 08:01 AM
H60_Driver
1997 - 2003 F150
Oct 26, 2016 11:02 AM
Reid Krabill
2004 - 2008 F150
Aug 10, 2015 09:40 AM
xlsportrider
1983 - 2012 Ranger & B-Series
Apr 6, 2008 09:42 PM
