Bleeding Power Assist Steering
Old Jan 11, 2013 | 02:49 PM
toddev's Avatar
toddev
Hi all!
I'm going to be replacing the power assist ram (bendix) on my 77 f250 as it is leaking. I don't imagine this will be too difficult, but I'm unsure as to the proper way to bleed the system.
I've searched the forums and I now know way more than I did about the system overall, but no idea how to properly bleed it.
I think the previous owner had not used the right fluid. I'd love to bleed in all new fluid if possible. Type F atf according tho this thread:
https://www.ford-trucks.com/forums/1...ng-system.html
Is it just a matter of replacing the ram, then jacking up the front end and cycling left/right a few times? Any help from your experience is very much appreciated!
Thanks!
-Todd
Old Jan 11, 2013 | 03:53 PM
montana_highboy's Avatar
montana_highboy
That's pretty much it, though it will probably be more like 60-80 times, there's a lot of hose/line to bleed all the air from, remember to use type F .
Old Jan 11, 2013 | 03:56 PM
toddev's Avatar
toddev
Thank you so much for the reply! I'll do it 100 times!
This should be fun...
-todd
Old Jan 11, 2013 | 11:07 PM
Riderman's Avatar
Riderman
-todd
<Montana is not wrong, but 100 times is a little excessive. Those arriated bubbles can be a bitch. Just drive it or let it sit overnight after cycling it a few times will work.
Old Jan 12, 2013 | 10:47 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
See if this gives you any help....
https://www.ford-trucks.com/forums/1...ering+bleeding
Old Jan 12, 2013 | 03:37 PM
toddev's Avatar
toddev
Thanks for the link! That one didn't come up in my search. This will surely save me lots of time/labor. I really appreciate all the help. Hopefully I can contribute something soon!
-todd
Old Jan 12, 2013 | 03:40 PM
77&79F250's Avatar
77&79F250
Ok and post up how you get along with the earthquakes68's advice as it applies to your 77 and the power assist sys, hopefully it will.
Old Jan 12, 2013 | 03:56 PM
montana_highboy
It won't work on power assist, power assist uses a manual gear box.
Old Jan 12, 2013 | 04:04 PM
77&79F250's Avatar
77&79F250
Yea I sort of figured that with my statement, but was just trying to offer some sort of help.
mkoecher
Jul 27, 2018 10:06 AM
djed
Jul 9, 2016 05:47 PM
cam360
Sep 1, 2012 06:50 PM
dew487
May 25, 2007 05:59 PM
98xlt4x4
1983 - 2012 Ranger & B-Series
21
Oct 8, 2004 05:56 PM
