Tire question
Old Jan 11, 2013 | 04:59 PM
tecgod13's Avatar
tecgod13
Originally Posted by FORDF250HDXLT
but i really had to set her down best i could cus this stuff doesn't just load itself.
besides lifting hurts economy,this is why i can't swap in a d60.i can't afford the lift in the rear to match the extra front height.already wish the truck sat 6" to a foot lower in the rear when loading and i'm over 6'.
thankfully i finally recently got a dump trailer for the larger stuff,but still always will be tossing stuff up into the dump bed of course as well.towing a trailer when you know your load will fit in the bed is cheaper on fuel to leave the trailer home.compromises.so many compromises.
I don't want to sidetrack this thread... but.. How much space do you have between the tires and the bed FORDF250HDXLT? And have you thought of airbags?
You'd have to figure out just how many springs you need (or none with 4-link type setup?). And I'm not sure how it would effect the ride and handling. But then you could drop the bed right down until its basically resting on the tires for easier loading, then jack it back up again for travel.
I do agree with you about keeping the rear low. I did swap a D60 into my truck, which raised the front about 5 inches.... There weren't any blocks on the rear axle, so it looks like I'm sagging in the rear all the time, but I just don't want to jack it up and have to lift everything higher (I'm only 5' 6" so that doesn't help either).
Old Jan 11, 2013 | 05:14 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I hear ya about loading tall trucks.
My vans rear end sits very high, and it's a pain to load bodies in it from the back, or even get in from the back, and i'm 6'.
It sits on 235/85 tires though, with 10 leafs springs on each side.
I'd like to remove some leafs....but for some reason I kinda like the nose dive look.
kdh74
1983 - 2012 Ranger & B-Series
May 24, 2017 06:40 AM
PW01
Escape & Escape Hybrid
25
Feb 8, 2012 12:54 AM
F15090300
Nov 13, 2005 02:07 PM
77300i6
Aug 31, 2005 07:20 AM
CherryColaholic
Bronco II
Nov 19, 2004 05:44 PM
