Modular V10 (6.8l)
V10 missing under load
Old Jan 9, 2013 | 06:43 PM
Loopy's Avatar
Loopy
While driving to work doing about 50 mph going up a slight incline, the motor got sluggish pulling up the hill. Pulled over and could feel it at stop with the brake on. Put in park and could not tell really at all. Put it back in drive and really felt it around 40-45 mph. The truck is a 2000 F250 CC 4X4. She's got 75,000 on her with probably the original plugs and coils.
Old Jan 9, 2013 | 10:13 PM
jh818's Avatar
jh818
Go ahead and change the plugs and rubber boots since you think they're still the original. You need to have it done anyways. That may fix your misfire. If not, then you'll need to find out which cylinder/coil.
Old Jan 10, 2013 | 07:07 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
When left alone for long periods of time, these Ford modulars like to suck dirt and moisture down into the spark plug holes. I'm willing to bet you have a pile of crud in at least one of the holes
Old Jan 10, 2013 | 08:05 AM
Treker58's Avatar
Treker58
I bought my X V10 about 175 miles from my home. On the way back when I was going through the mountains, I noticed that when the engine was under a load, I was getting a misfire, stumbling situation. Was fine on the levels. Was told in the Excursion forum to check the COP boots, sure enough they were not in the best of shape and not one drop of dielectric grease on any of the boots. New boots and a dose of dielectric grease problem gone
Old Apr 30, 2013 | 03:48 PM
Ridenred333's Avatar
Ridenred333
I wish the op would let us know if he did anything as I am having the same issues.
Old Apr 30, 2013 | 03:50 PM
Ridenred333
Gonna try doing this over the weekend.
Old Apr 30, 2013 | 06:59 PM
Wolfboro's Avatar
Wolfboro
2000 F250, V10 @75,000 miles
Do you know if the fuel filter has ever been changed ?
Old May 2, 2013 | 12:48 PM
ltj211's Avatar
ltj211
I'm having a similar situation, but im not so sure mine is a misfire. At around 40-45 mph and at 13-1500 rpm (and only when I'm trying to accelerate, like after someone pulled out in front of me) the whole truck will stutter. It's almost like it's trying to shift but can't, or like it shifts and immediately decides it shouldn't have and shifts back. If I give it more gas the rpms go up, it down shifts and gets me up to speed, no problem. Any ideas? 99 SD v10
Old May 2, 2013 | 04:02 PM
cole1996's Avatar
cole1996
This is almost word for word what happened to my 99' F-250 V-10!
The only way it got fixed was all spark plugs and brand new (Accel in my case) coils. Also did fuel filter, the gas coming from it was dark brown!
Cole
hblanchard
Oct 18, 2011 12:36 PM
Andy's250
Oct 17, 2010 08:43 PM
mike bell
Jul 21, 2010 09:07 AM
nautidog
Feb 22, 2006 10:53 PM
baldpc
Modular V10 (6.8l)
16
Sep 12, 2004 06:49 PM
