Sponsored by: Real Truck
'02 v10 slight missing
Old Oct 17, 2010 | 04:15 PM
Andy's250's Avatar
Andy's250
My dad has an '02 4dr lb 2wd v10 auto, bone stock 150ish k miles. It has developed a miss in the past and his mechanic has put one or two coil packs on it and it cleared it up for awile, it is doing it again now. would it be a better idea to just change the 6 stock ones that are left all at one time, and also anyone know a good cheap place to find some if thats what is neccesary
Old Oct 17, 2010 | 05:47 PM
redford's Avatar
redford
FTE Leadership Emeritus
A quick way ti know if it really is a miss is to put the truck in drive and depress the throttle while your other foot is planted on the brake. Just put the engine under load, do not break the rear tires loose.
If you have a miss it will show up doing this.
It may be a COP, but my guess is a bad boot is causing this.
Old Oct 17, 2010 | 08:03 PM
Andy's250's Avatar
Andy's250
Im sorry but im pretty gasoline retarded, by boot do you mean sparkplug boot? thanks for the response, it does definately miss under load
Old Oct 17, 2010 | 08:43 PM
redford's Avatar
redford
Yes, the spark plug boot.
A COP is a pretty simple item. It is basically a step up transformer, basically 2 coils of wire. While the wires can sometimes break, there isn't much in them to cause occasional misses.
A dirty, wet or perforated boot can cause these symptoms.
Also, when were the plugs last changed?
foxv10
Jan 5, 2011 08:32 PM
nicebenz68
Engine Swaps
Mar 9, 2009 12:37 PM
ExcursionUSA
Mar 10, 2007 02:16 AM
