Hello. My '77 ford has some serious play in the steering and i tracked it down to the ball and stud on the front of the control valve. it has the bendix style steering. i can't find a rebuild for it anywhere. any help? thanks, dave
Denns Carpenter has 1077 in stock
Here are a few more:
Bayer Ford Mercury, Comanchee, TX has 1 (325) 356-2777
Crossett Ford Lincoln Mercury, Crossett, AR has 1 (870) 364-2162
JST Automotive, Lebanon, TN has 1 (870) 364-2162
Green Sales, Cincinnati, OH has 5 (800) 543-4959
Wesley Obsolete Parts, Lebanon, TN has 1 (606) 787-5293
Was the excess play present while the engine was running, or shut down? when the engine isn't running and the system isn't under pressure, there is some play in the ball stud, this is normal.
When the system is powered up (engine running), the play disappears because the hydraulic action moves the linkage as it is supposed to.
The ball stud does not move the linkage, all it does is actuate the control valve and pressure system, it is the power cylinder that moves the linkage as it gets pressurized fluid from the control valve.
