Having trouble with my power steering control valve (Bendix) trying to find one in Canada?? I can get a rebuild kit for a 2 wheel drive? but not for 4x4 ??
Thanks for the website been there already, I modified the control valve with a washer. The spring in the control valve was a little weak so I added a washer and it work better !! For now until can afford another control valve.
Power Assist P/S only installed in 4WD's, so there's no such thing as a 2WD rebuild kit.
Bendix Power Assist: 1974 F250 4WD from serial number T80,001, 1975/76 F250 4WD, 1977 F250 4WD before serial number Y20,001 (all High Boys).
Well my washer fix was short lived,blew the supply line,had a new one made,removed the washer,now it steer's fine turning right but steering to the left is harder!!? Waiting for a rebuild kit! Just hope it holds together until it shows up?
