rough Engine vibration
Old Jan 7, 2013 | 01:30 PM
call4jr's Avatar
call4jr
Can anyone recommend a good diesel shop in the south bay area? I am getting a bad engine vibration when it shifts into overdrive. (03 F250 6.0l) When the truck is in lower gears and the RPMs are around 2K the vibration is mostly gone. Seems like an injector issue, but I really have no idea.
Thanks
Old Jan 7, 2013 | 04:43 PM
run6.0run's Avatar
run6.0run
Does it idle smooth???
Old Jan 7, 2013 | 05:50 PM
call4jr's Avatar
call4jr
no - has uneven idle
Old Jan 7, 2013 | 10:31 PM
04badford's Avatar
04badford
south bay nor cal? do you have any gauges most of us use a scan gauge II from auto zone ford x gauge will scan and look at all of your sensers plus some, very handy tool for the 6.0 s. sanjose or more inland? Blades has the 03 so lets hope he will chime in let me know your city if yall cant come to a conclusion.
Old Jan 7, 2013 | 10:57 PM
04badford's Avatar
04badford
call 4 jr have you done the noted
1. OEM fuel filters
2. drained water separator
3. OEM oil filters
4. checked oil level
5. cleaned ICP senser
6, cleaned MAP senser and tube
7. IPR and check the screen
8.( EBP and Tube).
IF you have a gauge look at
ICP,MAP,IPR
sorry guy lots of things to look at but icp and Ipr would be the first .check the tech folders icp and ipr will be under the turbo down on the block.
Old Jan 9, 2013 | 02:52 PM
call4jr's Avatar
call4jr
thanks for the advice - I replaced the IPC sensor a few months back, but I will definitely follow your tips on the rest. If none of these fix the problem, do you agree I should have injectors checked? (again - not throwing an engine code so I'm not sure) I have heard Raineri's is a good shop if I need one, any others in the south bay area?
Old Jan 9, 2013 | 03:37 PM
BLADE35's Avatar
BLADE35
Sounds like injector
IDK any shops there but You can go post in that area chapter
Old Jan 9, 2013 | 03:57 PM
call4jr's Avatar
call4jr
San Jose, Calif
Old Jan 9, 2013 | 07:51 PM
RideDiesel88's Avatar
RideDiesel88
Do you have aftermarket exhaust?
Old Jan 9, 2013 | 08:53 PM
Fal-308-Win's Avatar
Fal-308-Win
A good shop in the north bay is " Left Coast Diesel "
Old Jan 9, 2013 | 09:01 PM
Fal-308-Win
Left Coast Diesel has two shops. One in Concord and the other is in the East Bay Area
Old Jan 9, 2013 | 09:02 PM
RideDiesel88
I know a 4" downpipe can rumble on the intake manifold when in 5th gear low rpms. i wrapped mine up with the old heat shield and that 'drone' went away. But if shes idling erradic your probly on the right track with injectors
Old Jan 9, 2013 | 09:54 PM
04badford's Avatar
04badford
call4jr, I would think If Inject you would have a contibution code,the pipes could be like ride deisel had mentioned,you really need to scan gauge this there is so many sensers in our trucks , ICP do you have oil out of the plug side if not pull it and clean it up with carb cleaner also the plug too they get a little greazy ,you can do a test wiggle the connection and see if truck does what your saying ford sells a pig tail,next would be MAP and connection to the EGR cooler that little hole gets plugged, when was the last time you pulled the EGR they get pretty gunked up when you pull the egr put new o-rings back on her.now you have some home work lol
Milwaukee1979F150
13
May 7, 2012 04:57 PM
lexasgs400
Sep 6, 2007 11:04 AM
coglesby
Nov 27, 2003 01:36 PM
Gr8ride
Feb 22, 2003 12:17 PM
