got my cab lights installed..
Old Jan 6, 2013 | 07:17 PM
Lukes66's Avatar
Lukes66
Let me know what you think!
Old Jan 6, 2013 | 07:32 PM
FoundOnRoadDominatin's Avatar
nice job man. looks nice
Old Jan 6, 2013 | 11:22 PM
siloketh's Avatar
siloketh
Looking great. What all was involved?
Old Jan 7, 2013 | 08:37 AM
Lukes66's Avatar
Lukes66
I sat the lights on the cab until I had a good idea of the spacing I wanted to use. Then I made a poster board template that had the hole sin it for the bolts and wires. I laid the template on the roof and used a pencil to mark the spots to drill. Next I drilled pilot holes for the sheet metal screws and larger holes for the wires. Here is a pic of the template.
I angled my outer lights a tad bc I thought it looked good. I didnt use anything to insulate the wires from the holes I drilled but if one of them ever rubs through, it will just blow my fuse. One things I did wrong was to use silicon to seal everything up, I need to clean that mess up and find out a better way to seal it up. My lights came with gaskets but they seem to trap water against the cab in the gasket contact area.
Old Jan 7, 2013 | 08:59 AM
Corner Gas's Avatar
Corner Gas
Looks good.
Old Jan 7, 2013 | 09:12 PM
mark1986F150's Avatar
mark1986F150
Looks good man, where'd you get the kit? I want to put cab lights on my truck but my wife said she wouldn't be seen in it with me if I did... lol. I would recommend putting something in there to insulate the wires from the holes you drilled... grommets can be had fairly cheap, or you could use some vacuum line that's split so you can put it around the wire. As far as silicone goes... I've had good luck taping off an outside border for it... put the silicon on, let it set up a little bit, run a razor blade along the edge of your tape and peel the tape up. Leaves a nice clean edge.
Old Jan 8, 2013 | 07:04 AM
Lukes66's Avatar
Lukes66
The light kit was a cheapo from ebay. I think it was 19 dollars a few years ago.
Old Feb 15, 2013 | 11:17 AM
Lukes66's Avatar
Lukes66
I moved some photos around and broke the links,so here they are again.
rbooe05
Oct 20, 2024 02:25 PM
X1Lightning
Apr 17, 2018 01:03 PM
17 Oaks
Nov 25, 2017 03:47 PM
5 on a side
Oct 25, 2015 06:25 PM
03_PSD
Oct 16, 2008 09:58 AM
