Sponsored by: Auxito
speedometer not working right
Old Jan 6, 2013 | 03:40 PM
mattg529's Avatar
mattg529
I just recently bought a 1997 ford f150 xlt. The man I bought it off of said he changed the ECM and the speedometer stopped working. Here is the troubleshooting I have done so far. I checked the ECM and the ECM part number matches the one on the passenger door. When I hook up the VSS on the rear nose cone on the transfercase the speedometer will work but, I am traveling approx. 35 mph the speedometer says 95 mph, and the odometer doesn't move at all. On the transfer case I have 3 connectors 1 is a 4 wire connector, 1 is a 1 wire connector, and the VSS is a 2 wire connector. Do I have a bad VSS or is it something else?
specs.
1997 Ford f-150
4.6 liter engine
Manual Transmission
4wd
Any help would be appreciated thanks.
Old Jan 6, 2013 | 04:51 PM
vaper's Avatar
vaper
Almost like the ecm thinks it's in low range.I had 92 f250 7.3 e40d do that because of a blown fuse but it was the shift patterns that were all screwed up.
Speedo was right but it would go into 3rd gear at about 15 mph
Old Jan 7, 2013 | 09:34 AM
F100classics's Avatar
F100classics
The gear on the VSS itself or the gear in the tail housing, on the output shaft, need to be perfect for the speedometer to work correctly. If they are worn at all the speedo will jump or miss calculate your speed. the gears are made of plastic and my 1997 flareside's speedometer was off and would "jump" on the freeway. It's something to look into.
Old Jan 7, 2013 | 01:15 PM
mattg529's Avatar
mattg529
ok thanks I will check the gear on the VSS and the transfercase.
Old Jan 11, 2013 | 01:39 PM
mattg529's Avatar
mattg529
Finally got all the parts today. and changed the ABS speed sensor on the rearend, and changed the speed sensor on the transfercase. I still have the same speedometer problem. I also checked the ECM again just to make sure it was right, and checked the plug to the ecm and it was all good. Just don't know where to go now. Someone said that there is another speed sensor on the transmission, but I can't find another one. Is there really another speed sensor? Thanks
went back out to troubleshoot a little more and decided to check voltages on the speed sensors. I have 5.00 volts on the sensor on the rear end, and 0.00 volts on the sensor on the transfer case. I was under the impression that there should be 5 volts on both of them.
Old Jan 11, 2013 | 02:39 PM
vaper's Avatar
vaper
speed sensor issues - Ford Truck Club Forum
Apparently the vss on the tansfercase is only for the shift module,the one in the diff is for the speedo.Maybe a wire broken somewhere?
Old Jan 15, 2013 | 04:54 PM
mattg529's Avatar
mattg529
Did any 97 f150's come with 4 wheel ABS? I can't find any sensors on the front of my truck, and when I used the VIN decoder it said it has "class D" brakes. My question is can the ABS control module be at fault because it is the only thing I haven't checked? Also where is the module located on the truck?
Old Jan 21, 2013 | 02:15 PM
mattg529's Avatar
mattg529
i changed the RABS module and had the same problem. So I have in narrowed down to PCM, the cluster, or the wiring between them. The sensor on the trasfercase should it have any voltage on it? The rear abs sensor on the rearend has 5 volts.
overhaulin
25
Jul 15, 2014 12:37 PM
tundraathome
1997 - 2003 F150
Jan 11, 2008 12:38 PM
munrow
Mar 9, 2005 09:35 AM
Frdbuy8589
Aug 25, 2003 07:24 PM
