Sponsored by: Auxito
speedometer
Old Jan 11, 2008 | 12:16 PM
tundraathome's Avatar
tundraathome
speedometer
i have a 98 ford f150 4wd auto that has just now decided to have no speedo. the odometer continues to work which sort of tells me that the vss is sending the signal. i have no idea where it is located and any help as to determining the problem and solution is appreciated . it has an analog type speedo thanks sam
Old Jan 11, 2008 | 12:38 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The speedometer reads from the tailshaft of the transmission. There is a plastic gear in there that relays the speed through the cable up to the speedometer. Since your odo still works, I would bet that there is something broken in the gauge cluster (perhaps a small, plastic gear).
