So, Rustywheel, in your opinion, do I use the new engine to repair the 352; put the 360 with the refreshed heads together and call it a day; or look for a 390 crank and rods to create a 390?
If the option was your to make, what would you do for a daily driver.
If the 360 is running properly, I'd put a set of cheap headers on it, and drop it in.
Anything on the new motor I should check out before I put it in? You know, as long as it's out.
Also, being a 360 that is set up for an automatic, I'm guessing it sat in front of a C6, my 352 sits in front of a Cruise o Matic. Anything need to happen to make the 360 work with t the Cruise o Matic?
It wouldn't hurt at all to swap cams while it's out.
