Sponsored by: Auxito
ABS brake vibration
Old May 27, 2003 | 03:44 AM
BossHawg's Avatar
BossHawg
ABS brake vibration
I need you guys expert advice again. I have a 2000 F150 with pretty much The Works in options. Recently I have noticed a thumping vibration in the front suspension when I apply the brakes. Most guys are telling me it is a natural phenonemon of ABS. If thats the case, why didn't I feel that vibration right after I bought the truck, over 2 years ago. I hope some of you mechanical geniuses can give me a clue to what is going on.
Thank You
BossHawg
Old May 27, 2003 | 04:54 AM
Jimmy Dean's Avatar
Jimmy Dean
ABS brake vibration
Any hcance you have been off-road lately? possibly right before you started feeling this? this includes a gravel road?
Old May 27, 2003 | 08:56 AM
Racerguy's Avatar
Racerguy
ABS brake vibration
HI BossHawg and welcome to FTE
During normal braking you should feel no difference between ABS or non ABS brakes. If you're applying the brakes hard enough to lock up the tires and for the ABS to kick in, you will notice the thumping/pulsating but not during normal braking.
Could it be as simple as warped rotors? I think that's what I'd put my money on.
Old May 27, 2003 | 10:04 PM
BossHawg's Avatar
BossHawg
ABS brake vibration
OK, thanks for the responses. No, I haven't been off-roading.
Sounds like I need to take it in for a check up.
Thanks again!
BossHawg
Old Jun 1, 2003 | 11:09 PM
nldj13's Avatar
nldj13
ABS brake vibration
Boss, did you find out what the problem was? I put ceramic pads on my '99 this past weekend. Rotors turned, bearings packed, even replaced the anti-rattle clips (after thump began). The thump started as soon as it was lowered from the jack stands. Does it once a revolution and only going forward. Thump is synchronous with speed. Reseated the rotor today and replaced clips; seems to be the outer pad slipping but not sure.
If you find out let me know. Sorry for the length.
Old Jun 2, 2003 | 08:12 AM
BossHawg's Avatar
BossHawg
ABS brake vibration
nldj, No I havent had time to take it in to a certified mechanic, as yet. Everyone I talk to at work says its probably a warped rotor. Man, this truck only has 21,000 miles on it. I cant quite believe brakes would wear out that fast. Im wondering if it has something to do with the front 4X4. We had a really snowy winter this past year, and my 4X4 was engaged a good bit of the time. You are supposed to back up about 10 feet after you disengage 4X4, right? How do you know if the front actually disengaged?
Thanks,
BossHawg
Old Jun 2, 2003 | 09:26 AM
nldj13's Avatar
nldj13
ABS brake vibration
Thanks Boss. Sorry I can't help with the 4x4. Warped rotor, however, would seem to make sense with brakes heating up in snow. Good luck
Old Jun 3, 2003 | 09:53 PM
Jimmy Dean's Avatar
Jimmy Dean
ABS brake vibration
Esay, swap to manual locks, that is my first real project other than breaks and the such on the truck I just bought 91 4x4
Old Jun 4, 2003 | 09:29 PM
BossHawg's Avatar
BossHawg
ABS brake vibration
Thanks Jimmy, I will seriously consider manual locks. In the meantime, I will be getting my truck checked out by a certified mechanic within the next week, to find out what the problem is. I will be back to let nldj know what I found out.
Thanks,
BossHawg
Old Jun 6, 2003 | 01:38 PM
nldj13's Avatar
nldj13
ABS brake vibration
Boss, the problem was the ceramic pads. I still had pad left from my old shoes and decided to eliminate the shoes as a variable. I was shocked when the thump went away. I believe it was just those particular pads. The guy at NAPA pulled an identidal box to compare with my pads. While the shoes were the same, the numbers stamped on the pads did not match, the new shoes had the shims already attached and the new box had a hardware kit with it that mine did not. I'm going to run the old pads since there is some left. Turning the rotors fixed the vibration that caused me to change the brakes to begin with. Sorry for the length and good luck with yours.
Old Jun 6, 2003 | 08:29 PM
Racerguy's Avatar
Racerguy
ABS brake vibration
Thanks for letting us know what happened.
There can be quite a difference in materials on brake pads.
Old Jun 9, 2003 | 06:10 PM
BossHawg's Avatar
BossHawg
ABS brake vibration
Had my truck checked out today, and I'm somewhat embarassed. The problem was merely well worn pads chewing up the rotors. After new pads and turning the rotors, the vibration is gone.
Thanks for all your help and insight, fellows, and you all have a great summer.
BossHawg
Old Jun 9, 2003 | 10:24 PM
Freddd's Avatar
Freddd
ABS brake vibration
Ouch - shot pads at 21,000...
I was ticked at 80,000kms
BossHawg
2010 - 2014 Ford SVT F150 Raptor
Nov 15, 2011 09:24 PM
BossHawg
Sep 6, 2010 05:55 AM
BossHawg
Offroad & 4x4
Mar 26, 2009 09:42 AM
BossHawg
1983 - 2012 Ranger & B-Series
Aug 11, 2007 07:28 PM
BossHawg
1997 - 2003 F150
Jan 9, 2004 07:33 AM
