Heat Problems
Old Jan 5, 2013 | 12:14 PM
Boss94's Avatar
Boss94
Heat Problems
Hey everyone, I have a 1994 F150 straight 6 manuel 4x4 without A/C and my heat doesnt really work. The vents blows out hard but it's barely warm when the trucks temp gauge is at normal. Could this be the thermostat? Any help appreciated
Old Jan 5, 2013 | 12:22 PM
fdude64's Avatar
fdude64
sounds like the thermostat could be stuck open or the heater core is stopped up
Old Jan 5, 2013 | 12:37 PM
Boss94's Avatar
Boss94
Oh ok thanks, how do I check to see which one if not both are the problem? And how do I fix that?
Old Jan 5, 2013 | 01:17 PM
88n94's Avatar
88n94
What does your temperature guage show after it has been fully warmed up? I know some of these guages aren't terribly accurate, but.
Old Jan 5, 2013 | 02:01 PM
Boss94's Avatar
Boss94
The temp gauge reads normal at about the middle of normal after it's had plenty of time to warm up. I've even driven for an hour straight and the trucks heat is hardly even warm at best. It doesnt really bother me that much, but everyone that rides shotgun complains all the time so I decided to finally look into it
Old Jan 5, 2013 | 02:02 PM
fdude64's Avatar
fdude64
well you can just replace the thermostat and see if that helps or you can unhook your heater hoses at the block and water pump and try to back flush the heater core
Old Jan 5, 2013 | 02:09 PM
Boss94's Avatar
Boss94
Ok I'll try that, thanks for the help
Old Jan 5, 2013 | 02:12 PM
fdude64's Avatar
fdude64
just remember the hose going to the water pump is the outlet and that is the one you want to flush it from
dinebito
1978 - 1996 Big Bronco
Jan 9, 2010 06:13 PM
kolb02
Jan 25, 2008 12:52 AM
tommy55925
Feb 7, 2007 01:06 PM
Jrock909
Dec 22, 2004 11:21 PM
pjizzo
Dec 22, 2004 05:16 AM
