Heat problem
Old Dec 21, 2004 | 09:57 AM
pjizzo's Avatar
pjizzo
Heat problem
My 95 Explorer heater blows out warm air. The heat guage registers only slight movement while engine is running. When engine is turned off, the heater guage creeps up to a higher reading. Is this a thermostat problem?
Old Dec 21, 2004 | 10:44 AM
DEDON45's Avatar
DEDON45
I would guess a bad temp. sensor.
Old Dec 22, 2004 | 05:16 AM
marragtop's Avatar
marragtop
When you say heat gauge, I assume you mean the temperature gauge. If it's barely moving, it sounds like it is stuck open. I suggest installing a new thermostat.\\
Mike
