ICP problem?
Old Jan 4, 2013 | 11:57 AM
Tugly's Avatar
Tugly
Originally Posted by allkhaki
Thanks tugly. I will keep on eye on that today as I drive around. Would a faulty MAP sensor cause this? I dont have a check engine light at all.
I had a MAP issue once, and the CEL would be triggered... depending on the problem with it. The MAP and the Exhaust Back Pressure signals that will effect nuances in tuning and fuel efficiency, but you haven't described anything that takes us that far into troubleshooting. I have had air in my oil countless times because of oil changes and modifications to the engine. The truck is slow to start and runs a little weird until I either drive long and hard, or just drive about 50 miles and let it sit overnight. You'll know more tomorrow.
Old Jan 5, 2013 | 11:22 AM
allkhaki's Avatar
allkhaki
OK, drove quite a bit yesterday. Still not a lot of power at acceleration. Starts great even in the cold and idles real nice but just doesn't have the same power it used to. I cleaned the EBP tube today and it didn't change anything. Any other thoughts?
Old Feb 5, 2013 | 07:45 AM
allkhaki's Avatar
allkhaki
UPDATE: I replaced the ICP sensor about 3 weeks ago and all is well. My lack of power was due to a disconnected turbo intecooler pipe. Didn't see it on my first inspection as it was not obvious. I guess I did not tighten it enough after doing the UVCH mod.
Thanks to all for the help!
Old Feb 5, 2013 | 08:14 AM
howellt39's Avatar
howellt39
Yep, that would definitely cause a lack of power. Nice work diagnosing and fixing everything yourself.
Welcome to FTE, by the way.
Old Feb 5, 2013 | 10:49 AM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
Great Job! Welcome and enjoy the threads that will be. There are great people on this site and great information is shared. Not necessarily as timely as some would like, but it is there none the less.
Drew76924
Mar 14, 2019 03:33 PM
Kvfd6530
Feb 7, 2013 10:05 AM
01PS
Nov 2, 2011 11:37 AM
BigTires
Oct 6, 2011 09:14 AM
scottm1
Jun 25, 2011 02:34 PM
