Mystery Leak
Old Jan 2, 2013 | 12:50 PM
Nabors's Avatar
Nabors
Mystery Leak
I have a 290k mile 7.3 and there is a leak coming what looks like from somewhere above the starter where the transmission bolts to the engine. I'm sure there is someone here who has tackled one of these a time or two!
Old Jan 2, 2013 | 01:18 PM
Brother Les's Avatar
Brother Les
What year truck? What are you leaking? Is it oil or fuel? There is a 'drain hole' on top of the engine that will allow fuel/oil to drain off that leaks from the top of the engine. Climb up top of the engine while it is off and see if there is liquid down it the valley of the engine. A problem this time of year (cold) is that o-rings on the drain valve will contract and allow fuel to drain out into the hose. Some will go down the tube and some will go around the tube and drain into the valley.
Old Jan 2, 2013 | 01:30 PM
trekbasso's Avatar
trekbasso
Need more info. There are a few things on top that will leak down on either side. The fuel line has a fitting with a rubber sleeve on the passenger side, rear of head. The line itself will leak further toward the front of the motor and will leak down around the starter. The fuel bowl, hpop lines, orings.
Need a good cleanup and start looking.
Old Jan 2, 2013 | 01:40 PM
Nabors's Avatar
Nabors
It is a 2000. It's definately oil. I will check the various things you have told me and will check back in.
Old Jan 2, 2013 | 05:16 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
I am sure it is coming from somewhere in the valley. It could be the turbo pedestal, HPOP, IPR, or even the oil rail plugs on the back side of the engine.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Jan 2, 2013 | 05:30 PM
F250_'s Avatar
F250_
There have also been a few reports of an oil leak from the driver's side oil cooler actually crossing the engine and showing up near the starter.
Old Jan 4, 2013 | 11:48 AM
Nabors's Avatar
Nabors
I looked in the valley and it is very oily. I'm going to degrease it and make sure that is where it's coming from. I'll be back here soon with more info.
Old Jan 4, 2013 | 12:28 PM
allhuntalltime's Avatar
allhuntalltime
The high pressure oil line where connect to the HPOP are bad about leaking.
Old Jan 21, 2013 | 06:34 PM
gengine's Avatar
gengine
Any luck? My hpop developed a huge leak today...
Old Jan 21, 2013 | 08:02 PM
clem1226's Avatar
clem1226
Dipstick adapter flange?.....Its right behind the starter and oil will be blown back on to the bellhousing/transmission inspection cover as you drive.
willis72
Jan 20, 2015 02:45 PM
pilgrimbizket
Nov 16, 2013 02:05 PM
newblder
Sep 8, 2011 01:34 AM
ghig1967
Dec 11, 2009 06:23 PM
7.3PSD
Jan 12, 2007 01:43 PM
