Coolant leak
Old Jan 2, 2013 | 11:59 AM
waterboy_fishing's Avatar
waterboy_fishing
Coolant leak
It seems like I am leaking coolant possibly near the rear of the motor. What possible causes would there be for that and how difficult are they to repair? I noticed it while changing my oil.
Old Jan 2, 2013 | 12:08 PM
npccpartsman's Avatar
npccpartsman
Unless it's been previously changed there's a short red hose between the EGR cooler and oil cooler housings that goes bad and should be upgraded to the blue hose. It usually leaks when temps fall below 40 or 50. That's the most common leak. It's really more towards the front of the motor but runs down the valley and off the bell housing of the tranny.
Old Jan 2, 2013 | 02:08 PM
waterboy_fishing
Is it complicated to change?
Old Jan 2, 2013 | 06:28 PM
cheezit's Avatar
cheezit
for me no not at all. but thats a relitive question. something for some people are harder then they should be
Old Jan 9, 2013 | 08:26 PM
jlarsen513's Avatar
jlarsen513
I seem to be having this same issue. I'm wondering if I'm seeing the hose you are talking about. Is it kind of under the turbo?
Old Jan 10, 2013 | 11:38 PM
Regulator1988's Avatar
Regulator1988
im having the same issue its like a puddle on the passenger side near the rear
Old Jan 11, 2013 | 02:15 AM
VQT's Avatar
VQT
If you install the coolant filter, check the connection of the "T" and look for the wetness below the "T" on the head cover. Mine leak there.
johnsonjf
Dec 19, 2018 06:51 PM
onuredneck707
Oct 12, 2011 10:29 AM
04scurs
Dec 10, 2009 11:04 PM
sonneborn3
Mar 4, 2009 07:13 AM
neverman
Jan 18, 2007 02:26 AM
