Coolant leak.
Old Feb 25, 2009 | 10:09 PM
sonneborn3's Avatar
sonneborn3
Question Coolant leak.
I have a coolant leak, it looks like it is coming from the rear corners of the heads, but it is on both, so it must be leaking above and running down the heads, right? I took the air intake and degas bottle off today, and looked everywhere, but could not locate the actual leak. The heater and radiator hoses look fine. The only other thing to leak coolant on top of the motor would be the EGR cooler?? Or am I missing something else? It is so hard to check, as most of the motor is under the cowl (you know what I mean) and I really didn't want to remove the turbo today. Any suggestions???
Old Feb 26, 2009 | 08:02 AM
jmaskew's Avatar
jmaskew
Check the rubber hose on the egr cooler. I have heard these will leak. What color is yours?
Old Feb 26, 2009 | 10:02 AM
sonneborn3's Avatar
sonneborn3
The color of my hose? I can't even see it...I would say it's black, like the rest of the hoses.
Old Feb 26, 2009 | 01:39 PM
skoveng's Avatar
skoveng
The cooler supply hose should be red/orange or blue, about 3" long. It can be found directly behind the EGR down in the valley. The newer one is the blue hose. I still the the red/orange one on my truck. It will leak everyonce and a while, usually when its warmer (60deg) then turns cold (30deg). I plan on changing mine this spring. If you search the site, you will find photos and replacement instructions.
Old Feb 26, 2009 | 02:50 PM
sonneborn3's Avatar
sonneborn3
If it is the EGR hose, time for a delete. My warranty expired in January. Any suggestions for an economical delete kit, or a DIY solution?
Old Feb 26, 2009 | 07:29 PM
sonneborn3's Avatar
sonneborn3
I looked a little better today, found the hose for the egr cooler, it is red, kind of nasty looking, so I bet that is the culprit, are they hard to replace??
Old Feb 27, 2009 | 06:33 AM
skoveng's Avatar
skoveng
sonneborn3,
Do a search on this site for the replacement procedure. You'll have to remove the turbo but won't have to remove the manifold.
Steve
Old Mar 3, 2009 | 07:04 PM
sonneborn3's Avatar
sonneborn3
Where is the best place to get the hose?
Old Mar 3, 2009 | 09:20 PM
jmaskew's Avatar
jmaskew
I would get it at the dealer if you have one close by or by one of the site sponsors that sell Ford parts.
Old Mar 4, 2009 | 07:07 AM
sonneborn3's Avatar
sonneborn3
What are everyone's opinions on the $150 EGR kit on ebay? Do you think that would be a quality, economical solution?
Old Mar 4, 2009 | 07:13 AM
skoveng's Avatar
skoveng
Yes, I would (am) getting it from the dealer. I'll be doing mine this spring or next fall.
I have been saying that for the last two years though! It looks like a lot on the ground but the level in the bottle changes very slightly.
My truck now has 112K on the clock and I have not yet dug into the engine compartment (except for oil and fuel filters). I plan on spending a nice shade-tree weekend taking off the intake hoses and checking things out; the hose replacement will be on the list.
