Sponsored by: Auxito
sudden shutdown
Old Jan 2, 2013 | 07:05 AM
stihlcut's Avatar
stihlcut
sudden shutdown
I started my truck this morning, 97 4.6 4x4,after just a minute it just suddenly shutdown as if I turned off the ignition,the dome light flashed about 4 times and that was it.I turned off the ignition and then tried to restart but would not.
Old Jan 2, 2013 | 08:23 AM
RLGJ's Avatar
RLGJ
When you tried to restart what happens. Does it turnover at all.
Old Jan 2, 2013 | 04:09 PM
Lime1GT's Avatar
Lime1GT
Loose, corroded battery cable clamps??
Old Jan 2, 2013 | 04:16 PM
khadma's Avatar
khadma
Carpenter Local 745
Is it a cranks, but no start
Or nothing at all when turning on ignition?
Old Jan 2, 2013 | 04:57 PM
stihlcut's Avatar
stihlcut
problem solved guys, thanks.The issue must have been a bad cable connection.Put this in your your bag...With a bad connection I have never heard of this.It started good,no problem,I say this because most know if a ford does not have a good connection 9 times out of 10 you get the click.click.click.Ok keep going...the lights never went dim like a battery drain with charge,the engine just died like I turned of the igniition...instantly..then would not get the click when i tried to restart.it was like the battery was dead ,but i still had interior lights(bright)...and headlights worked fine.a real head scratcher..the only thing i figure is maybe the battery ground cable?
Island'r
Jun 4, 2018 01:42 AM
pounder90
1997 - 2003 F150
Dec 23, 2016 08:25 AM
1977HB351m
22
May 12, 2015 10:55 PM
lurch460
Jun 26, 2010 06:12 PM
DBGrif91
Jun 24, 2010 07:31 PM
