Truck dead- ignition switch?
Old Jun 24, 2010 | 03:22 PM
DBGrif91's Avatar
DBGrif91
1991 F150 5.8
Acts like it's a dead battery, but when I jiggled the tumbler I got the dome light to come on and the alert tone started going off. But then as soon as I tried to start it, acts like the battery is completely dead- won't even click. Tried jumping it and didn't get so much as a crank, so I'm guessing ignition switch or something related to it.
Suggestions?
Thanks.
Old Jun 24, 2010 | 03:34 PM
White 97 xlt's Avatar
White 97 xlt
Check the battery cables!!! All of them, both ends!!!!!!
99.9% chance you will find your problem....
Old Jun 24, 2010 | 04:40 PM
DBGrif91's Avatar
DBGrif91
Well I replaced the positive cable about 2 weeks ago, so perhaps it's time I give the negative cable a look...
Old Jun 24, 2010 | 05:01 PM
topdogcustoms's Avatar
topdogcustoms
check the starter mine did the samething
Old Jun 24, 2010 | 05:36 PM
DBGrif91's Avatar
DBGrif91
Starter is brand new. Replaced it about the same time I replaced the bat. cable 'cause I thought that was the problem at the time.
That's not to say a brand new starter can't be bad, but I'll look at the negative bat. cable first.
Old Jun 24, 2010 | 07:14 PM
White 97 xlt
Well a bad starter is not going to kill all power to the truck....Think about this for a minute!!!!!! So check the cables very close, try putting jumper cable from neg post on battery to the engine block, that should bypass the neg cable at least enough to prove if it is at fault... And recheck the pos. cable you replaced recently, could it be loose somewhere?
Old Jun 24, 2010 | 07:31 PM
DBGrif91's Avatar
DBGrif91
+1 to your rep for the correct answer. I cut some insulation off the negative cable and found the fibers to be very dark- a good indicator that the cable is bad. Quick run to the parts store for a new cable and a half hour later, all is well. I guess I should have checked the negative cable when I replaced the positive.
Thanks again for the help.
mattri
13
Jun 20, 2014 09:34 PM
bulldogcountry1
Sep 21, 2009 10:57 AM
mward69
Dec 14, 2008 07:39 AM
73f100shortbed
27
Oct 12, 2007 06:57 PM
coreygeorge
1983 - 2012 Ranger & B-Series
May 5, 2006 09:14 PM
