I bought the Power Slot rotors and Bendix pads for the X and they work great. I bought the power slot rotors and EBC yellow pads for my F350 and those are also great. The rotors on my X were warpped so thats why I upgraded.
My friends use EBC on their trucks, but I've had fantastic results with OEM pads. I put on a set at 88k with them not completely worn out due to going on a long trip and didn't want to worry about them. The ones on there now have 99k miles on them and they still have over a quarter of the pad all the way around. I don't tow that heavy with the X anymore. That might change my mind. Whichever you use, you may want to change the rubber lines out too as they have a tendency to get mushy and swell under heavy braking when they get older.
I just installed a set of Brakemotive drilled and slotted rotors with the powerstop ceramic pads. Done the bedding process and the beast stops on a dime. I am thoroughly impressed with the stopping power it has now. It stops better than my 1/2 ton Dodge Quad cab.
I concur. I have the same drilled, slotted rotors with ceramic pads from Brakemotive, and all I can say is WOW! Stock is NOT good enough on these. The difference is night and day between stock and what I am running now.
