boost gauge install
Old Dec 26, 2012 | 06:09 PM
Donzi Dude's Avatar
Donzi Dude
boost gauge install
My son got glow shift gauges and we will be installing them soon, the question is where is the best place to tap in to the intake manifold?
Old Dec 26, 2012 | 06:16 PM
BLADE35's Avatar
BLADE35
I think Most TEE Off the Map Sensor Line
Or some do itt at the 90* Intake Elbow
But if there is ever a Drivability Problem you will have to use the OBDII Port and check the MAP/EBP sensors So for that reason I am Not a Big Fan of AfterMarket Gauges
Old Dec 26, 2012 | 06:32 PM
MisterCMK's Avatar
MisterCMK
Right at the intake elbow is where I did mine.
The factory boost gauge and MAP are not entirely accurate with the SRL tunes BTW.
Old Dec 26, 2012 | 06:38 PM
BLADE35's Avatar
BLADE35
What makes you say that????
Old Dec 26, 2012 | 07:14 PM
BLADE35's Avatar
BLADE35
I know its so it will produce more Power
one of the reasons we take the tunner Off to Diagnos a Drivabilty issue
Old Dec 27, 2012 | 08:20 PM
MisterCMK's Avatar
MisterCMK
I got the info straight from the horse's mouth and I can see it on the boost gauge that I installed compared to the MAP readings.
The truck defuels at 28.xpsi of boost.
Old Dec 28, 2012 | 01:03 PM
raptor131's Avatar
raptor131
Look in my gallery, I tapped it on elbow engine side , the elbo comes off real easy, drill and tap it, them reinstall
Ford Truck Enthusiasts User Gallery
muskydawg
Jan 28, 2017 07:23 PM
joe blow
Apr 8, 2011 10:10 AM
884x4broncoII
Jan 24, 2008 08:33 AM
sweet03cobra
May 10, 2005 11:56 AM
Monster Duty
Sep 12, 2004 10:42 PM
