gauges
Old Jan 24, 2008 | 12:46 AM
884x4broncoII's Avatar
884x4broncoII
gauges
where are you guys installing your aftermarket gauges. id like to install a boost gauge and maby a couple others but want it to look clean and more or less oem. also where are you guys insalling your sender units for your boost gauges do you have to drill and tap into the manifold?
Old Jan 24, 2008 | 08:33 AM
tjbeggs's Avatar
tjbeggs
Here is where I have mine. The three on the pillar look factory but the two on the dash don't
For the boost gauge you can just T into the MAP sensor hose for the easiest install.
