Boost gauge
Old Jan 28, 2017 | 08:54 AM
muskydawg's Avatar
muskydawg
Boost gauge
Morning Fellas! I'm going to put some gauges on my '97 350. Boost and EGT. I already have tranny temp.
Question. How much difference does gauge quality make? I was checking out the glow shifts and they look sweet, but, amazon has other gauges for a fraction of the price. Has anybody used these other cheap ones? Also what ranges do I need for boost 0-30 or 0-60, and what will my peak EGT be?
Thanks guys!
Old Jan 28, 2017 | 09:05 AM
oldbird1965's Avatar
oldbird1965
I once bought a real cheap one on ebay and it didn't work at all. I then decided to buy a glow shift for one manifold and a isspro for the other manifold. The isspro will read 100° higher then the glow shift but they work very well, so far. Get a boost gauge over 30 lbs because future mods will get you over 30 lbs. Peak temps should not be over 1225°.
Old Jan 28, 2017 | 09:18 AM
farmert's Avatar
farmert
In my opinion, get the best gauge you can afford. I would recommend Isspro or Stewart Warner. I have the Glowshift gauges in my 97, and the pyro works off and on. I got the higher boost gauge range, and I think it is hard to read, as the number lines are closer together. If you are going to leave the truck close to stock, you probably won't see 30 lbs. of boost anyway. I put Autometers in the 96 C&C truck, and the pyro quit in about 6 months. The Isspeos and Stewart Warner gauges are still running fine.
Old Jan 28, 2017 | 11:15 AM
BBslider001's Avatar
BBslider001
I have Glowshifts in both of my OBS trucks with good performance. I don't have a problem with them. Some have, but I have not. I think they were worse in the older days but now they have come around and are pretty decent gauges for the money.
Old Jan 28, 2017 | 11:23 AM
fordman67's Avatar
fordman67
My 08 and 05 model auto meters work a-ok and never have given me a seconds hassle. Where I come from its auto meter or nothing. I can't comment on any of these off brand gauges because I have never owned any of them. They may be OK .... But I will never know...
Old Jan 28, 2017 | 07:23 PM
Bob_T's Avatar
Bob_T
I have Auberins digital gauges for trans temp, EGT and fuel pressure.
Automobile Gauges : auberins.com, Temperature control solutions for home and industry
All three have been in service for about a year and work perfectly. You can also calbrate them to get pretty accurate measurements. Some guys prefer needles, I don't mind digital numbers.
FordOwnerJoey
Nov 17, 2013 09:55 AM
hedhntr
Oct 30, 2011 11:55 PM
john8403
Apr 8, 2011 09:43 AM
Bubba828
Mar 24, 2009 08:22 PM
Lance_I
21
Jul 23, 2006 12:34 PM
