HX35
Old Dec 31, 2012 | 11:28 PM
  #46
racer30's Avatar
racer30
Yes there is some advantage to a true twin scroll system. they spool just a bit faster from consistant pulse from the seperate pipes into the exhaust housing. If you change the up pipe to be better shaped Y you will be ahead of the game.
Old Jan 1, 2013 | 11:44 AM
  #47
Ford_Six's Avatar
Ford_Six
Pulse timing and balancing them into the turbo will make a difference in efficiency, but not enough to matter a whole lot in an application like this. If you have a smooth y then it'll help quite a bit. There is an odd cylinder out on each side so you would need some really fancy headers to time the pulses all into the turbo evenly with a fully dual-path setup. Something like this:
For our purposes, if you bring the two sides together before the turbo and have a sort of collector for both sides, it will even out the pulses and make for more efficient operation.
Old Jan 1, 2013 | 07:16 PM
  #48
racer30's Avatar
racer30
Ya I agree not a problem to spend that much effort on. Its hard enuff just to plumb the exhaust to the turbo and back down to the exhaust pipe in that small area in a truck. I'm real lucky to have all the room to do my system. I can open the engine cover/bed in the MotorHome and sit on the trany and work on the turbo super easy.
Old Jan 1, 2013 | 07:25 PM
  #49
Twistedwrench's Avatar
Twistedwrench
I was looking at firewall clearance today and it's tight but not terrible . My truck still has the factory plastic sound deadener on the firewall so I'll have to put some sort or heat reflector on the firewall .
That will have to be first on the list as I'm sure I'll have no room to get in there and apply anything .
Old Jan 1, 2013 | 07:56 PM
  #50
hairyboxnoogle's Avatar
hairyboxnoogle
Originally Posted by Blind Driver
I'm wondering if there will be a problem if the pulses meet each other at the turbo, or can someone make the calculations so the pulses will alternate when they hit the turbo.
This all depends on the length of the pipe to the turbo.
Full length custom headers that collect into the turbo flange.. Not realistic, feasable, nor would it net a whole lot imo. If going twins, sure maybe then, some custom shorties (think ricer stuff) but for a single or compounds just do eet.
eldomike51
22
Sep 5, 2016 11:57 PM
351Cleveland C4
37
Aug 23, 2012 06:49 PM
alteredspeed
18
Feb 9, 2010 06:21 AM
Ford4x4-JD70AB
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
15
Sep 7, 2006 07:29 AM
robertleeii
Oct 3, 2003 11:41 AM
