rear stabilizer bar causing vibration ???
Old Dec 21, 2012 | 04:11 PM
kevind95's Avatar
kevind95
I 'm having a vibration it is bad between 40 and 50 and only when excellerating and under a load it is twice as bad the u joints and the carrier bearing are fine and the alignment is just a little off but it's a whole separate sound. the stabilizer rods and bushings are bad and wiggle could this be causing the vibration
Old Dec 21, 2012 | 07:29 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
i don't think it would the stabilizer bars causing issue, but if they are worn out they need replacing. check your leaf spring hangers and shackles.
Old Dec 21, 2012 | 07:55 PM
kevind95's Avatar
kevind95
Originally Posted by '94IDITurbo7.3
i don't think it would the st6abilizer bars causing issue, but if they are worn out they need replacing. check your leaf spring hangers and shackles.
they are creaking and squeaking a lot and I've been throwing a lot of miles in the last 2 months I'm getting ready to pull over to check these out I guess I'll just looking to see if they're loose
Old Dec 21, 2012 | 08:18 PM
'94IDITurbo7.3
the hangers could be broken and if they are original there is a good chance they are broken. let me find some pics of mine.
Old Dec 21, 2012 | 08:33 PM
'94IDITurbo7.3
these were mine.
Old Dec 21, 2012 | 10:22 PM
turtlemann14's Avatar
turtlemann14
and if they are broken they could be putting stress on the drive-shaft making the growl
Old Dec 21, 2012 | 10:43 PM
kevind95's Avatar
kevind95
Ouch how did you fix it. Welded no doubt.
Old Dec 21, 2012 | 11:05 PM
kevind95's Avatar
kevind95
I'll check it tomorrow and get back 250. How about the torque converter. Will they vibrate?
Old Dec 22, 2012 | 09:43 AM
turtlemann14
buy or make a new one, metal that is being used for that purpous likes to flex alot and become impossible to weld. you just cut the large rivets off and punch them out. reinstalling with grade 8 and lock tight.
devovino
Jul 9, 2019 01:11 PM
bigpoppapeak
Apr 8, 2019 09:14 AM
heavytruk
16
Mar 30, 2009 02:34 PM
HKusp
Feb 29, 2008 10:48 PM
GregN
Oct 26, 2007 09:48 AM
