lift kit question
Old Jan 6, 2013 | 12:15 AM
newpy383's Avatar
newpy383
lift kit question
I am hoping someone can answer this for me. I just installed a skyjacker 6 inch lift on my 78 f250. It sits pretty nose high. Do they settle down after awhile? I am not using the factory rear blocks because i got new springs front and rear and the instructions said not to use the blocks if i wanted it to sit level. Should I wait awhile and see if the front end comes down or put the blocks back on? This is my first lift kit so any help will be appreciated.
Old Jan 6, 2013 | 07:58 AM
garthneddy's Avatar
garthneddy
It will settle, but it's hard telling exactly how much. My lifts always seemed to settle in a couple weeks while being driven daily.
Old Jan 6, 2013 | 08:27 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I don't know, those skyjacker 6" use some robust front springs, I bet you will have an inch or so of settle, but I always had to run the factory 2.5" block in the rear, to keep things right. No block seems strange, no bump stop either.
Old Jan 6, 2013 | 09:14 AM
newpy383's Avatar
newpy383
Thanks. I haven't had the chance to drive it yet. I haven't changed over the steering yet. It sits a good 2 inches higher in the front. I think i will put the blocks back on and go from there.
Old Jan 6, 2013 | 01:42 PM
fordcrzymike's Avatar
fordcrzymike
Since you replaced both front and rear springs I would think they would settle about the same amount, so I think adding the blocks would be a good idea. You can always remove them if you have not achieved your desired ride height.
LCrowe2012
Feb 25, 2014 01:59 AM
john8403
Feb 3, 2012 09:17 PM
bearit
Offroad & 4x4
35
Mar 18, 2008 07:11 PM
rosco_p_coltrane
Aug 20, 2006 03:54 PM
stebab
Jan 9, 2006 12:04 PM
