48 F4
Old Jan 27, 2013 | 06:16 PM
  #46
Sheepdog48's Avatar
Sheepdog48
Just pulled the motor & transmission tonight here's the required pictures
Old Jan 27, 2013 | 06:19 PM
  #47
Sheepdog48's Avatar
Sheepdog48
Pulling them out together was a tight fit with the grill still in place but its out.
Old Jan 27, 2013 | 06:55 PM
  #48
raytasch's Avatar
raytasch
Believe Nothing
Good job. Keep the pictures coming. Tear down or replace?
Old Jan 27, 2013 | 07:00 PM
  #49
Sheepdog48's Avatar
Sheepdog48
Hi Ray, I plan to tear down and see if a rebuild will be possible, if not I" ll replace, I want to stick to a flat head.
Old Feb 8, 2013 | 08:32 PM
  #50
Sheepdog48's Avatar
Sheepdog48
This is what I came up with for a flywheel puller, most use that weight has ever seen. But it did work, just don't drop it on your toe.
Old Feb 9, 2013 | 06:40 PM
  #51
Sheepdog48's Avatar
Sheepdog48
I got the pistons out tonight, even the frozen one it took more than a little persuasion. The motor has been apart before one of the rods is marked remand by FM and another is a different color, same as re-maned one. The cylinders are sleeved, was this common practice or were the cylinders too bad to simply bore? I'am also wondering if anyone has come across this on a rebuild, can I get new sleeves pressed in?
Old Feb 9, 2013 | 06:51 PM
  #52
raytasch's Avatar
raytasch
Believe Nothing
What is the condition of the bores? Possibly a very light honing and go back with what ever size you have. Another possibility is an overbore of the sleeves although some shops may not want to do it. My concerns would be condition of and tightness of the sleeves.
Have you figured out why it stuck? Signs of water intrusion?
What is the condition of the bottom end?
What is the condition of the valves?
Get it cleaned up and go from there.
Luck
Edit:
You won't know if a re sleeve is possible 'till you find out how much the engine was bored and if the bore is in good shape. It is possible they bored into the water jacket and the sleeve leaked.
Old Feb 9, 2013 | 07:01 PM
  #53
Sheepdog48's Avatar
Sheepdog48
My guess is a warped head. The stuck piston had a about an ounce of rusty crud looked like coffee grounds on top of the piston. There is also a good amount of rust in a couple of the exhaust ports were the manifold bolts up. The bottom end looked good, crank journals nice and shiny. Picture of the crank won't load here is one of the pistons.
Old Feb 9, 2013 | 07:06 PM
  #54
Sheepdog48's Avatar
Sheepdog48
Forgot about the valves, still working on getting them out. I'am sure I have some that are stuck. I'am soaking them tonight and going to try to get them out tomorrow. Thanks for your help Ray much appreciated.
Old Feb 9, 2013 | 11:59 PM
  #55
Rojak's Avatar
Rojak
Reading this thread is giving me F4 envy! If you are an orphan F4 out there and need a good home please contact me immediately...
Old Feb 10, 2013 | 12:28 AM
  #56
Jolly Roger Joe's Avatar
Jolly Roger Joe
Don't know how I missed this thread..
Welcome (a little late) to FTE!
It's great to see another F4 being saved. And your truck looks to be in great condition to start with.
Old Feb 11, 2013 | 10:14 PM
  #57
DRMBailey's Avatar
DRMBailey
Anybody with 18" widowmakers out there for these F4s? Looking for some options.
Old Feb 11, 2013 | 11:48 PM
  #58
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Yes, the 18" widow makers can be replaced with 19.5" x 6" Budd #89340 tubeless wheels. The 7" x 18" tires on your truck are probably about 33.5" to 34" tall which is almost exactly the equal of an 8R19.5" radial. Here's a link to a new 18" tire in the Universal Tire catalog to show its sizing. I'm not suggesting that you think about buying these, nobody would want to mount them on your widow makers.
https://www.universaltire.com/truck-...transport.html
For comparison here's an 8R19.5" spec'd.
Bridgestone R187 8R19.5 267-775
If this solution interests you, below is a link to an ad I have in the FTE classifieds for a set. Stu
https://www.ford-trucks.com/forums/1...wo-sets-2.html
cruisetopdown
32
Sep 23, 2015 07:03 PM
Dangerousdave
25
Jun 14, 2008 02:02 AM
Dadsf-21952
Dec 29, 2007 11:41 PM
jpjahn
19
Dec 26, 2005 12:06 AM
Hyper
General Automotive Discussion
Jun 9, 2004 02:52 PM
