Cleanest Engine Compartment
Old Dec 18, 2012 | 11:47 AM
bly8397's Avatar
bly8397
I've been wanting to clean up a little under the hood. Would love to see pictures of everyone's engine and some tips on how you got it looking of so nice, and to keep it looking great. It makes it easier to work with everything when you can actually tell what is what and everything isn't coated in a desert tan color.
Old Dec 18, 2012 | 11:55 AM
Crewcab Turbo's Avatar
Crewcab Turbo
I used Simple Green.
Old Dec 18, 2012 | 12:09 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I use Simple Green also.
<CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER>
I will clean my engine again after I repair my fuel drain valve tonight. Will take a newer pic this weekend.
Old Dec 18, 2012 | 12:12 PM
VegasFordSD's Avatar
VegasFordSD
^^Same, use some simple green and hose it down. Obviously try to keep away from electrical connections as much as possible. Some use armour all after, just soak everything down with it, the armour all will make everything shine. Cleanup your IC pipes, add some color accents and it will be looking good. I still have a lot more plans for mine (just haven't had the time and money lately). I plan to get a new degas bottle, and clean things up a bit more.
BEFORE CLEANING
AFTER CLEANING
Old Dec 18, 2012 | 01:11 PM
F250_'s Avatar
F250_
Simple green, soak, rinse with low pressure water. Once it is dry, I use a discontinued product called Teflon Tire Shine (I came across some in a Big Lots after it was discontinued, so I have a little supply to last me for a while longer).
Cover your relays and open element air filter with plastic bags before hand.
Do NOT forget to remove the bag from the air filter before starting your engine!!
Below is a link to my gallery where I have some before/after shots from one of my cleanings.
https://www.ford-trucks.com/user_gal...e+while+longer.
Old Dec 18, 2012 | 01:12 PM
HH60FE's Avatar
HH60FE
I'm not posting any pics. Mines clean but not cleanest!!!!
Old Dec 18, 2012 | 01:54 PM
Tugly's Avatar
Tugly
I'm developing a complex here... this was a lousy idea.
[LINK] [LINK] [LINK] [LINK]
Old Dec 18, 2012 | 02:17 PM
jeffreyt's Avatar
jeffreyt
I just buy a new truck when my engine gets dirty.
Old Dec 18, 2012 | 02:49 PM
VegasFordSD
That motor is pretty clean Jeffery, hmmm guess I better go shopping for a new truck now too!
Old Dec 18, 2012 | 04:13 PM
tappit01's Avatar
tappit01
1 gallon Simple Green® Pro HD Heavy-Duty Cleaner
is this the right stuff , the purple?
chris
Old Dec 18, 2012 | 04:18 PM
trekbasso's Avatar
trekbasso
Your link didn't, but as long as it's Simple Green, and doesn't have warnings about using it. Purple Power is a no no. Too caustic.The brand name Purple Power.
Old Dec 18, 2012 | 04:44 PM
tappit01's Avatar
tappit01
Simple Green Pro HD
how about now.
Old Dec 18, 2012 | 05:09 PM
VegasFordSD
Originally Posted by tappit01
Simple Green Pro HD
how about now.
http://www.simplegreen.com/products_...se_cleaner.php
This is what I use... but that purple stuff looks like it would be good stuff
Old Dec 18, 2012 | 05:18 PM
trekbasso's Avatar
trekbasso
Simple Green Pro HD
how about now.
I hadn't noticed that before but should be fine.
Old Dec 18, 2012 | 05:21 PM
helifixer's Avatar
helifixer
this thread is where the sick minds hang out!!!!!! my '97 has 220,000 + miles my '99 has 300,000+ miles and mt '00 excursion has 160,000 miles and none of them have eve been cleaned
