Washington Chapter Washington Chapter
Join Chapter, Leader: Tim Young
January meet
Old Jan 5, 2013 | 08:12 PM
  #61
jgavac's Avatar
jgavac
Yep. My 87 is my dd anyway. Let's just hope the trans doesn't go out until afterwards
Old Jan 5, 2013 | 09:17 PM
  #62
joewelds's Avatar
joewelds
Just got back from the junkyard. Got a 130 amp alt. Hoping to get it installed before the meet. Took it to O'reily's and test good. Got the wires all the way to the fuse box (under the hood) I think it has the 175 amp fuse. Also got the positive wire to the starter. Pulled an other 175 a fuse from an other car as well. Ooh and the fuse box as well.
Old Jan 6, 2013 | 12:19 AM
  #63
GruesomeJeans's Avatar
GruesomeJeans
Sounds good. I can't say i have done anything with the bronco. Things have been slow.
Old Jan 6, 2013 | 12:50 AM
  #64
RavageX's Avatar
RavageX
I'll have to make an effort to make it out to the meet.
Old Jan 6, 2013 | 12:59 AM
  #65
GruesomeJeans
Well if you can't make it then you can't make it. There will be meets in the future.
Old Jan 6, 2013 | 10:11 PM
  #66
79F150400M's Avatar
79F150400M
Kirkland is very doable for me. Only problem is remembering on the 19th.
Old Jan 6, 2013 | 11:56 PM
  #67
GruesomeJeans
I put it in my phone's calender. I don't have a calender for this year yet so i can't write it there.
Old Jan 8, 2013 | 12:01 AM
  #68
jgavac's Avatar
jgavac
Sounds like we might have a good sized group for the meet
Jameson
Old Jan 8, 2013 | 01:35 AM
  #69
GruesomeJeans
Yeah we always think that... Then it is only a few that actually show up haha.
Old Jan 8, 2013 | 01:58 AM
  #70
oddfordjunkie's Avatar
oddfordjunkie
How did you identify the alternator as 130 amp? Hoping to have my Hydroboost brake setup on the truck before the meet.
Old Jan 8, 2013 | 02:12 AM
  #71
joshofalltrades's Avatar
joshofalltrades
for alternator ID, there was a small-case 3g used on smaller cars that looks like https://encrypted-tbn2.gstatic.com/i...7aVOtwZhL5MAyg its a lower output. the large case unit is what we all play with, and it looks like https://encrypted-tbn1.gstatic.com/i...3N9NvxqQsepvDA
notice the difference in how many holes are in the front of the case. in stock form, the large case units are always 130a, while the small case units are something less, IIRC 90 or so. note that the large case 130a come in a few different mounting styles. the best one to get can be found in the taurus with the 3.0. note that the 3.8 has the wider mounting, so it takes a bit more work to mount, but is functionally equivalent. most of the 4cyl cars came with the small case unit, which is not what you want.
Old Jan 8, 2013 | 03:10 AM
  #72
joewelds's Avatar
joewelds
Josh is right. If your looking at the front of the alt pully side, like from the front of your truck. The front of the alt's have spoke 's like a steering wheel, kinda. In the spokes are the holes you want to pay attention to. The 95 amp has four holes in the spoke's and the 130 amp has only two holes. When I went to the junkyard I expected it to be picked clean. Not the case. I had plenty to choose from. I grabed two. One tested good, one bad. Took it back and pulled an other one that test good. There are different mounting styles as well. Be sure to grab one the same as your truck. There are large case and a smaller case. The large is 8.25" the small 7". I got one of each. My truck has a 7", but as I am a welder I can make something pretty quick to house the 8.25". While you are there grab the wires that go to the alternator as well. I also got a fuze box and a couple 175 amp fuzes, those are mounted on the driver side. Just follow the wires over to it. Haven't installed it yet. Hopefully this week. If you have any more questions justn msg me
Old Jan 11, 2013 | 11:35 PM
  #73
Yahiko's Avatar
Yahiko
FTE Remembers
So next week for the meet
https://www.ford-trucks.com/forums/1...l#post12665291
Sean
Old Jan 12, 2013 | 01:05 AM
  #74
GruesomeJeans
I have an alarm set for my phone so I don't forget. I have to make sure I have gas the day before, I have been driving a lot lately.
Old Jan 12, 2013 | 01:09 AM
  #75
joshofalltrades
you gotta have gas, i gotta have diesel or whatever i find to pour in the tank.... whatever, i'll see you guys there next weekend
