Washington Chapter Washington Chapter
Join Chapter, Leader: Tim Young
January meet
Old Jan 1, 2013 | 07:33 PM
  #31
joshofalltrades's Avatar
joshofalltrades
that l6 would have a c6 behind it. AFAIK, thats the only automatic that was offered with a 300 until sometime after they went to fuel injection. and i've never heard of the c4 being used in any pickup, regardless of engine.
Old Jan 1, 2013 | 07:58 PM
  #32
GruesomeJeans's Avatar
GruesomeJeans
I agree with Josh up there, a C4 just doesn't seem strong enough for a trucks needs. And them 300's are some torquey buggers. I have seen a lot of threads where people throw a 5 speed behind them. I forget the name of the Trans but I think it starts with an F or something.
Old Jan 1, 2013 | 08:02 PM
  #33
joshofalltrades
there were 2 options of 5 speeds, the light duty "mazdog" m5od, or the heavy duty ZF. the 4 speeds are pretty common too. i've owned 2 trucks from the 80-86 era that both had the NP435, which is darn near bulletproof, i had one that survived running out of oil and only killed a synchro in the process, i drove it for a few months that way
Old Jan 1, 2013 | 08:20 PM
  #34
joewelds's Avatar
joewelds
Does the VIN have the info on which transmission I would have? If so here it is F15BRBAO398. Now I am wandering just what the H do I have.
Old Jan 1, 2013 | 08:37 PM
  #35
jgavac's Avatar
jgavac
This is what the vin says
Your Model Year is 1978.
Truck Series: F150 2 Wheel Drive
Engine: 6cyl - 300cid, 1BBL carb, 120 HP
Assembly on: San Jose, CA
If you look on the tag on the door jamb there should be a listing for trans code. I think C4's were used in the early 2wd f100s, in the 73-75 range for a dentside.
As far as the meet goes, I can probably make it. Did we decide on a date?
Old Jan 1, 2013 | 09:04 PM
  #36
joshofalltrades
looks like we were going for the 19th at the pizza place detailed in post #13, as that seemed to be the best day for everybody.
do we want to do 6 in the evening, or something different?
Old Jan 1, 2013 | 09:27 PM
  #37
jgavac's Avatar
jgavac
Whoops I must be going blind Good thing I'm getting glasses soon
5 or 5:30 would probably work well for me. Hell I suppose 6 would work too. Not much later though
Jameson
Old Jan 1, 2013 | 10:11 PM
  #38
Yahiko's Avatar
Yahiko
Pagliacci Pizza Bridle Trails
13005 Northeast 70th Place
Kirkland, WA 98033
Jan 19 @ 5:30 PM then
Sean
https://maps.google.com/maps?hl=en&i...d=0CJIBEPwSMAA
Let me know if the link works or is a dud
Old Jan 1, 2013 | 11:35 PM
  #39
GruesomeJeans
Linky works fine. Thanks Sean. 5:30 sounds good to me. Maybe for once I can be the first one there But anyways, I am looking forward to meeting any new kids on the block
Old Jan 2, 2013 | 12:05 AM
  #40
joshofalltrades
i'll try not to be the last one there this time
5:30 it is, see you guys then
Old Jan 2, 2013 | 12:32 AM
  #41
Yahiko's Avatar
Yahiko
If things work out I'll bering my new toys.
Ford IDS and hardware
Old Jan 2, 2013 | 12:45 AM
  #42
GruesomeJeans
Hopefully TGM will still be in good health around that time. It's been having issues with cold starts and idleing lately. And now my brakes are squealing even though they are fairly new
Old Jan 2, 2013 | 01:03 AM
  #43
joshofalltrades
oh, brake squeal. i have just the answer for that. take them apart and put a thin layer of grease on every point where the pads touch their mounting bracket and/or the caliper. might also grease the slides that the caliper mounts on.
Old Jan 2, 2013 | 01:11 AM
  #44
jgavac's Avatar
jgavac
Having issues with cold starts? You need glow plugs!
Is your choke adjusted right? Because usually cold starts and having a hard time idling means your choke isn't set high enough
Old Jan 2, 2013 | 01:19 AM
  #45
joshofalltrades
all he needs to do is swap out that 351 for a 420 and make sure he has good glow plugs - it'll run like a champ and be better on fuel
