Starter testing question
Old Dec 16, 2012 | 04:44 PM
Talyn's Avatar
Talyn
Okay, Being everything didn't work out as well as I wanted, I decided to pull the starter and bring it inside to let it dry out seeing as everything everywhere was wet.
One of my battery cable leads broke at the terminal, so I have to wait till tomorrow to fix that half.
So, being my batteries are testing good.
I redid the solenoid ground.
So. I bring the starter in and took the solenoid off from it to clean that. It was packed with dirt.
Looks like it might be the original actually. The cup inside is pretty worn.
So, I pop the starter gear out and grab it and try an turn it and boy is it hard to turn.
These are supposed to almost free spin are they not? Slight resistance?
I'm really hoping I don't need a new starter.
But then, If this means the starter is bad, then I can always tear it down and see if I can R&R it to make it work again.
Old Dec 16, 2012 | 05:26 PM
Action4478's Avatar
Action4478
It should turn rather easy.. What happened to it ?...
Old Dec 16, 2012 | 05:29 PM
Talyn's Avatar
Talyn
Started fine on sunday when changed oil. Went to start last night and it acted like batteries were low.
Drew enough power to reset the radio, but everything tests well.
Cleaned a bunch of connections and pulled starter.
Cleaned it up inside, poped it out and grabbed ahold and I gota twist it hard to get it to turn over.
I'm guessing that maybe too much moisture got in there?
I"ve never had an issue starting.
Old Dec 16, 2012 | 05:44 PM
Action4478's Avatar
Action4478
WHat happens on a bench test ?...
Old Dec 16, 2012 | 05:49 PM
Talyn's Avatar
Talyn
I don't have the capabilities to perform such actions.
Old Dec 16, 2012 | 05:53 PM
Action4478's Avatar
Action4478
a Battery charger Or battery & jumper cables ?
Old Dec 16, 2012 | 06:17 PM
fordpride's Avatar
fordpride
Yep ^^^^^^^^^^^
Old Dec 16, 2012 | 06:24 PM
Talyn's Avatar
Talyn
Neighbor destroyed my charger a few years back and my jumper cables were stolen.
Old Dec 16, 2012 | 06:25 PM
Talyn's Avatar
Talyn
Actually, I've had 2 pair of jumper cables stolen now I think of it.
Talyn's Avatar
Talyn
Either way. I can barely turn it by hand.
Old Dec 16, 2012 | 08:40 PM
BuckHammer's Avatar
BuckHammer
Might as well go get jumper cables. You'll want them on hand anyway if you're having issues starting the truck.
Old Dec 16, 2012 | 08:43 PM
Talyn's Avatar
Talyn
I literally have 15 dollars.
That's it
nothing more.
zip
zilch
no backup
nothing.
Old Dec 16, 2012 | 09:14 PM
BuckHammer's Avatar
BuckHammer
Dude, I feel you on that. Lol.
Old Dec 16, 2012 | 10:05 PM
Talyn's Avatar
Talyn
This has just been a horrible year in all honesty.
I'm thinkful for what I have.
Furr308
Jan 15, 2017 05:31 PM
bigdogchris
1978 - 1996 Big Bronco
Apr 28, 2012 07:21 PM
guitarnik
Sep 2, 2008 08:04 AM
DOUG5G
Aerostar
Sep 8, 2006 03:39 PM
Marc150
13
Dec 14, 2004 04:37 PM
