1982 351 windsor problem
Thanks
Not certain if you need help on removing the intake.
I would leave the carb on the intake and just remove the intake
and carb as one unit.
It may help to make a cardboard diagram of the intake about one foot
by one foot and then as you take out the intake bolts push them into the cardboard.
So the cardboard is like a little drawing of the intake and you push the bolts
into the cardboard to show position of each bolt.
Make sure to mark the cardboard so you know which end is the front of the motor.
1. - When removing the rockers and pushrods - - I like to use an egg-crate for the rockers and a cardboard for the pushrods. You want to re-install the rockers and pushrods in the same place as they came out of. THIS is important to try and keep things organized.
2. - Remove the rockers and pushrods - -remove the intake and the lifters are sitting right there.
When it comes time to re-assemble - -there are a number of things you need to keep in mind.
Installing the rockers is easy BUT the rockers need to be properly adjusted.
The intake needs to be torqued to a certain spec and in a special sequence or order.
Also when taking the intake down to torque
SEVERAL OTHER TIPS;
1. - When you remove the intake you have what we call an Open Motor - -be carful
that things DO NOT fall into the motor. Try to keep the valley area covered with a rag while doing other things after the lifters are out.
2. - Take some GOOD puctures of everything BEFORE you start to pull apart.
3. A product like ZDDP on the cam lobes and lifters will help with break in of the new ones.
4. Don't be too suprised to find a few flatened cam lobes also. If you see wear now is the time to address a new camshaft into it.
Good luck
If you want the tranny fluid to work, you will need to run it a couple of days or a week before it will knock anything loose. I have used a can of stuff called "Rislone" with some success in breaking up cloggedand sticky lifters.
P.S. If your engine looks like the above pictures, and you run the tranny fluid and the rislone in it, be ready to unclog the oil pump pickup.
Looks like the lifters are ok dont seem to see any damage. Oil filter is new but only seems to be half full new oil pump not sure if that is normal.
Anyone know if there is some kind of valve where the oil filter screws in?
