Sticky/noisy lifters
Old Jan 20, 2004 | 09:46 PM
Stingray42's Avatar
Stingray42
how do i fix this? is there an easy fix, or does it require pulling and redoin the heads? 1984 Ford F150 351 W
Thanks!
Old Jan 21, 2004 | 05:17 AM
RichardMaerz69's Avatar
RichardMaerz69
you do not have to pull the heads,but you do have to take the intake off.when you put the intake back on don't use the front and back gasket thier bad for slipping,put a good bead of rtv sealanton them instead,and double check to make sure nothing dropped in side.I tore an engine down that still had rags in it from the last person to work on it ,tore the bottom end apart
Old Jan 23, 2004 | 11:25 AM
Stingray42's Avatar
Stingray42
what do i have to do?
Old Jan 23, 2004 | 02:40 PM
RichardMaerz69
beafor disconeting anything mark all your hoses,and wiers so they can be instaled in the proper places afterbe carefull not to break anything in the process.Then drain your coolent,and disconect the top rad hose some fluid will run out,disconect all vacum lines and anyother lines going to the intake becarfull removing fule line their could be some pressure in the line,use a rag to unscrew it or pull it of witchever.Spray all bolts with a good penatrating oil don't be cheap you don't whant to break any bolts off.Scrape any lose dirt or grime from around the intake spray bolts a couple more times and reamove them,use a screwdriver to pry lose the intake lift up on the back and reamove it you might need help with this part.Reamove your valve covers and losen your rocker arms until you can reamove the pushrods and your lifters should comeout with a littel help from a magenet.reinstall in reavers be sure all your gasket surffaces are clean before putting itback together.If theirs anything I'v forgotten someboby please don't hesatate to critasise.
mrollings53
Oct 8, 2016 01:22 PM
bbyrnes1
Aug 18, 2016 09:56 PM
5speed50
2009 - 2014 F150
38
Jan 14, 2016 09:00 AM
jhcir
2004 - 2008 F150
Mar 19, 2004 07:33 AM
Stingray42
Jun 10, 2003 03:46 PM
