Information display ....
Old Dec 15, 2012 | 11:07 AM
jdadamsjr's Avatar
jdadamsjr
At some point I could scroll down thru the DIS menu in between the tach and speedo and select the last two icons - one a 'checkmark' ? and one and 'i' ????
now I can't, any ideas ?
I tried while driving, stopped, idling, key on only, off.....
Old Dec 15, 2012 | 07:33 PM
Andrew010's Avatar
Andrew010
Press the left arrow twice, on the directional pad on the left side of the steering wheel. You're most likely in a sub menu screen and need to get all the way back to the main menu. Then you can scroll through everything.
Andrew
Old Dec 17, 2012 | 08:27 AM
jdadamsjr's Avatar
jdadamsjr
Hmmm... on the main menu as it scrolls up and down fine thru the fuel mpg, towing, etc...
and the icons show up, but 'greyed out' - not selectable
software designer by trade - you'd think I could get it to work
but will give it a try
Old Dec 17, 2012 | 10:53 AM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
That's a bummer, You say you can scroll down through the fuel mpg, and towing, etc. Are they grayed out or just the bottom two icons?
Old Dec 18, 2012 | 09:53 PM
jdadamsjr's Avatar
jdadamsjr
the bottom two are greyed out / unselectable...
the other work fine....
very strange...
is there a menu option to turn that off anywhere ? Maybe the wife played with it
Old Dec 19, 2012 | 12:03 AM
Chad149's Avatar
Chad149
This took me a few minutes to figure out as well. Andrew is right by hitting the left arrow until you can go no more, then you can arrow all the way down. Your wife in the settings turned the memory to "on". This causes the menu to go back and forth to the same sub menus as you arrow up and down thru the menus and block out the bottom two unless your at the main menu screen(all the way to the left). Clear as mud?
Old Dec 19, 2012 | 10:09 AM
jdadamsjr's Avatar
jdadamsjr
Atta Boy gentlemen !!!
Moving to the left helped
Guess BECAUSE my group does that internetty stuff and one of the rules we have in place is 'don't offer what the users can't/shouldn't do..." blinded me ...
the menus are the same except the HOME menu is the aqua color... and has the ford icon.... now I know ---- until the next time Thanks again !
Old Dec 19, 2012 | 11:24 AM
Tim Young's Avatar
Tim Young
Good deal glad you got it figured out.
Midnite150
Dec 2, 2018 02:11 PM
ihawk16
6.4L Power Stroke Diesel
15
May 15, 2018 10:51 AM
4bigred
Mar 14, 2016 08:56 PM
Cecil_Stringer
Jan 18, 2008 10:16 PM
ksrdrunner
Modular V10 (6.8l)
Mar 29, 2005 01:43 AM
