Sponsored by: Real Truck
MPG display
Old Mar 14, 2016 | 11:36 AM
4bigred's Avatar
4bigred
MPG display
Earlier I stumbled onto a information display that showed both the average mpg and the gear the transmission was in. I liked having it displayed while towing. I lost it and can't find the combination to get it displayed again. The service advisor has seen it, but couldn't get it to display. Any advice?
Old Mar 14, 2016 | 01:07 PM
SHAWZER's Avatar
SHAWZER
Start your truck , put it in drive and push plus sign on gear selector ..Works on my 2015 XL .
Old Mar 14, 2016 | 01:09 PM
gasman6674's Avatar
gasman6674
To get the gear display press the plus/minus switch, it should toggle it on.
the left toggle on the steering column should allow you to get your avg mpg, its in the manual.
Hope this helps
Old Mar 14, 2016 | 02:11 PM
wrvond's Avatar
wrvond
What model do you have?
If you only have the standard message center then the following applies:
If you calculate your average fuel economy by dividing distance traveled
by gallons of fuel used (liters of fuel used by 100 kilometers traveled),
your figure may be different than displayed for the following reasons:
Your vehicle was not perfectly level during fill-up
Differences in the automatic shut-off points on the fuel pumps at
service stations
Variations in top-off procedure from one fill-up to another
Rounding of the displayed values to the nearest 0.1 gallon (liter)
1. Drive the vehicle at least 5 miles (8 km) with the speed control
system engaged to display a stabilized average.
2. Record the highway fuel economy for future reference.
It is important to press the RESET button (press and hold RESET for
two seconds in order to reset the function) after setting the speed
control to get accurate highway fuel economy readings.
MPG (L/km)
This displays instantaneous fuel economy as a bar graph ranging from
poor economy to excellent economy.
Your vehicle must be moving to calculate instantaneous fuel economy.
When your vehicle is not moving, this function shows , one or no bars
illuminated. Instantaneous fuel economy cannot be reset.
Old Mar 14, 2016 | 08:56 PM
4bigred's Avatar
4bigred
Thanks Shawzer and Gasman, that's what I was looking for.
Midnite150
Dec 2, 2018 02:11 PM
F2502011
6.7L Power Stroke Diesel
Jul 16, 2011 12:53 PM
Marauder92V
21
Jun 11, 2011 09:06 PM
Spindoctor
2009 - 2014 F150
Feb 7, 2010 07:17 PM
Cecil_Stringer
Jan 18, 2008 10:16 PM
