locking diff in back axis(I write the translator)
Old Dec 15, 2012 | 05:32 AM
denrus's Avatar
denrus
Guys prompt. I from Moscow. It was specially registered at you on this question. Would like to put differential with blocking in the back bridge. I have Ford F-150 2009, Heavy Duty.rear drive. At us snows has piled much, it is not convenient to go. Prompt what to take differential, number in catalogue Eaton Detroit Locker. Whether It is necessary to adjust after installation by washers a back axis. We have not enough information on this subject matter?
Old Dec 15, 2012 | 12:08 PM
MisterCMK's Avatar
MisterCMK
So you are looking for the part number for an Eaton locker for the rear differential on your truck?
Old Dec 15, 2012 | 12:44 PM
NASSTY's Avatar
NASSTY
Are you looking for a Detroit TrueTrac Limited slip carrier or a Detroit Locker?
What do you mean by Heavy Duty? Does your truck have the 34 spline 9.75" rear axle?
Old Dec 15, 2012 | 05:18 PM
smokersteve's Avatar
smokersteve
A selectable locker is the most ideal.
Old Dec 15, 2012 | 08:57 PM
meborder's Avatar
meborder
Eaton Catalog:
http://www.eaton.com/ecm/groups/publ.../ct_128302.pdf
Detroit Locker part number (page 4):
225C194A
Video of installation:
The video does not show the shimming process (washers). Most times shims (washers) are needed to get the proper gear mesh (alignment). This process should be familiar to anyone who has done rear axle work on similar vehicles.
i understand english is not your language and are likely using a translator to read this, so if anything is unclear, let me know and try the response again in hopes it will read better on your end.
Old Dec 16, 2012 | 05:45 AM
denrus's Avatar
denrus
thank you for a help.did want to know who can did put?Detroit Locker- it of 100 % blocking and with it speak not conveniently, and Detroit Truetrac with the partial blocking here number 913A477.913A477 | eBay.
Old Dec 16, 2012 | 05:47 AM
denrus's Avatar
denrus
Guys I can not define type of the rear axle. Either the first or the third, went to look. By quantity of bolts?Diff Wizard
Old Dec 16, 2012 | 05:48 AM
denrus's Avatar
denrus
Ford 10.5", '08-'10 or Ford 9.75" (9 3/4 inch), '08-'10
Old Dec 16, 2012 | 05:53 AM
denrus's Avatar
denrus
Vin 1FTVX1CV2AKA97027.My car http://www.ford-trucks-club.ru/showthread.php?t=21307
Old Dec 16, 2012 | 06:37 AM
NASSTY's Avatar
NASSTY
When I installed my Detroit True Trac (#913A477) in my 2011 F150 I purchased a shim kit because I thought I would need it. But ended up using the factory shims that were on my stock differential. Oh well, it was better to have them and not need them than to need them and not have them. The shim kit wasn't available locally so my truck could have been down for a week waiting for parts.
Old Dec 16, 2012 | 07:07 AM
denrus's Avatar
denrus
Thank you NASSTY. 913A477 and you do not know I have the same?Ford F-150 HD,on the wheel 7 studs
Old Dec 16, 2012 | 07:19 AM
NASSTY's Avatar
NASSTY
Yes, you also have the 9.75" rear differential.
Old Dec 16, 2012 | 07:31 AM
denrus's Avatar
denrus
Thanks my American friend)))At us cost Raptor price http://www.exoticauto.ru/cp-27-raptor.At all of you it is cheap
Old Dec 16, 2012 | 09:47 AM
denrus's Avatar
denrus
Originally Posted by meborder
Eaton Catalog:
225C194A
Jeep Drivetrain Winner: Installing Detroit Truetrac Differentials and Locker - YouTube
Thanks, all translated
bigblack74
Apr 20, 2023 12:02 PM
old blue beast
Apr 12, 2013 06:23 PM
86caprirs
Apr 19, 2008 04:26 PM
kwtoxman
May 31, 2004 11:32 PM
