Replace belt tensioner??
Old Dec 14, 2012 | 01:22 PM
wdglide's Avatar
wdglide
I was trying to release tension to change serp belt. I was getting a squeal when a/c kicked on and my volts were running low at idle.
Anyway I broke the tensioner turning it with 1/2" ratchet. Two questions:
1. Would a bad tensioner be the cause of the squeal?
2. How hard is the replacement of the tensioner? Any step by step instructions around.
Hope someone can chime in with help. Aaarrrrgghhh!!!!
Old Dec 14, 2012 | 02:56 PM
Special Ed's Avatar
Special Ed
2- 10mm bolts. Torque is 18 ft lbs.
Old Dec 14, 2012 | 02:58 PM
Special Ed's Avatar
Special Ed
You'll find out real quick if that was the squealer soon as you fire it up with the new one on there.
Old Dec 14, 2012 | 03:01 PM
sammie0126's Avatar
sammie0126
Give this thread a read it should help you out.
https://www.ford-trucks.com/forums/5...placement.html
Old Dec 14, 2012 | 05:24 PM
wdglide's Avatar
wdglide
Well, it wasn't too bad to swap out. Advance Auto had it in stock. She's up and running strong.
Old Dec 14, 2012 | 05:41 PM
69cj's Avatar
69cj
Was it your sqealer??
Old Dec 14, 2012 | 05:52 PM
wdglide's Avatar
wdglide
Can't say yet. The squealing wasn't consistent. The tensioner was definitely seized and I replaced the belt too. So, I suspect between the two my squealing and charging problems will be cured.
Old Dec 14, 2012 | 05:53 PM
69cj's Avatar
69cj
I'd bet your correct.
pbgsho2
Mar 30, 2011 08:00 AM
kennethpina
Dec 16, 2010 01:19 PM
andy wick
Sep 28, 2005 02:43 PM
MrBSS
Modular V8 (4.6L, 5.4L)
Aug 28, 2003 10:49 AM
spoon059
Mar 6, 2003 10:43 PM
