Having trouble using AE
Old Dec 13, 2012 | 05:37 PM
cutlass's Avatar
cutlass
I've used AE several times before and today after plugging it in to my truck, it displays a message that it's unable to communicate with Com Port 1. I have AE on the same configuration I always do. Does that mean an issue with my truck or AE?
Thanks,
Drake
Old Dec 13, 2012 | 05:43 PM
PaysonPSD's Avatar
PaysonPSD
Thanks,
Drake
Hello Drake.
Make sure the cig lighter has power (not the power point). OBDII port is the same fuse. Should be #3 under dash.
Pin 16 on the port should have 12 volts.
Old Dec 13, 2012 | 05:53 PM
cutlass's Avatar
cutlass
Thanks Robin! It was fuse #3 and everything is good now. Reps given.
Drake
Old Dec 14, 2012 | 05:58 AM
Tugly's Avatar
Tugly
Wow... that's what I call a detailed answer.
Old Dec 14, 2012 | 04:03 PM
PaysonPSD's Avatar
PaysonPSD
I could have tossed this in there and made it even more detailed.
File Type: pdf
cm6pack
Apr 24, 2013 10:42 AM
huntdiamondjim
Sep 2, 2011 10:29 PM
njneer1
Jul 18, 2011 08:53 PM
ToMang07
General Automotive Discussion
Jul 13, 2011 10:42 AM
firstrider
Oct 19, 2009 05:16 PM
