Sponsored by: Real Truck
very strange problem with scan tool
Old Sep 2, 2011 | 05:49 PM
huntdiamondjim's Avatar
huntdiamondjim
4wd High
hi guys was wondering if anyone else has had the a problem with reading their codes. i plug my scanner in and keep getting message that says tool not connected. scanner diffently works as i have other fords i checked it on. is there a fuse on something i should be looking for? ive tryed to search this forum but haven't seen this problem anywhere. i guess that means i'm special. by the way it is a 99 f350 with 225,000. so it has a little wearbut what a great truck it has been. thanks jim
Old Sep 2, 2011 | 06:17 PM
jc8825's Avatar
jc8825
There is a fuse for the OBD port, but I don't know which one.
Old Sep 2, 2011 | 06:23 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Check your cigarette lighter. Its on the same fuse. If it doesnt work, then the fuse it blown. That happened to me.
Old Sep 2, 2011 | 06:29 PM
ToMang07's Avatar
ToMang07
Yuppers...
Fuse Finding Frenzy Fiasco!
Old Sep 2, 2011 | 06:34 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
On a 1999 it should be fuse 3 under the dash. A 20A fuse.
Old Sep 2, 2011 | 08:31 PM
huntdiamondjim
4wd High
thank you trey and others
thanks so much for info. that was it!! read codes and believe it or not it is cyclinder 1 misfire. my lucky day!! thanks again jim
Old Sep 2, 2011 | 10:29 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Glad you got it fixed
cm6pack
Apr 24, 2013 10:42 AM
lowbed dud
Nov 21, 2012 04:35 PM
tomb391
May 24, 2009 11:13 PM
billcox
1997 - 2003 F150
Feb 20, 2006 06:20 AM
taltonallen
Sep 3, 2004 12:39 PM
