Starting whine (spin out)
Old Dec 10, 2012 | 08:28 PM
SC'79's Avatar
SC'79
About the only way to describe it. When I turn the ignition on either cold or hot start doesnt matter, sometimes I get a turnover then a whine that sounds like something spinning (Im guessing its the starter not engaging or becoming disengaged?) I turn the key off and have to wait for it to stop (takes a second or two). It doesnt happen every time and is fairly new occurance, but is becoming more frequent.
Truck is a 79 f150 automatic ranger short box with a 460 c6 np205.
New battery and cables, cranks strong when it doesnt spin out. Thanks
Old Dec 10, 2012 | 08:32 PM
HIO Silver's Avatar
HIO Silver
If it's more of a screech, check the belt tensions. Cold, hard, and stiff sbelt will momentarily slip before it gets a good friction bite. Spanning btwn the pulleys, adjust for no more than 1/2-inch of tension when pressing lightly in the middle.
Old Dec 10, 2012 | 08:45 PM
SC'79's Avatar
SC'79
Its not a screech, but more of a sound like when your using a power drill and let off the trigger under high rpms...Like it should be under a load but is let loose. When it starts making the noise, the motor stops turning over.
Old Dec 10, 2012 | 08:55 PM
HIO Silver's Avatar
HIO Silver
Is it more of a "zing" sound? Then I'd say that either the starter's teeth or ring gear/flywheel teeth are not engaging... maybe missing teeth or the starter isn't kicking out to engage the ring gear/flywheel.
Starters are easy to rebuild. Try it....it's a good learning experience.... about $20 for brushes and bearings.
Old Dec 10, 2012 | 09:14 PM
jetrinka's Avatar
jetrinka
I second the starter not engaging. If there is an inspection plate, i'd remove it so I could see the ring gear on the flex plate and turn the crank over to inspect all the teeth on it and make sure there isn't any damaged ones.
Old Dec 10, 2012 | 10:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
X3, it's either a bad ring gear or starter drive, probably both.
Old Dec 10, 2012 | 10:38 PM
wyckedcombo17's Avatar
wyckedcombo17
Inspect the teeth, if that's not the problem then it's the starter. Same thing happened on my truck, teeth OK, starter was spinning but the solenoid was not pushing the drive out to meet the flywheel.
I know the exact sound you're talking about
Old Dec 11, 2012 | 03:06 PM
SC'79's Avatar
SC'79
Where's the best place to get a rebuild kit? and would moving to one of the new mini high torque starters be a better choice than rebuilding the old unit?
Old Dec 11, 2012 | 03:21 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Finding out the problem first, like do you have fly wheel teeth missing, before you buy the high torque starter is what to do first. Just replacing the starter with a HT could only compound your problem.
Pull the starter and insp it, then have someone turn the motor over by hand (breaker bar and cheater pipe on the harmonic balancer bolt a little at a time) to insp the flywheel ring gear for missing teeth.
Use a paint marker to mark a start point on the fly wheel, and pulling the bottom insp plate will let you insp a larger portion at once.
Old Dec 11, 2012 | 11:01 PM
wyckedcombo17
Like 77&79 said, inspect it first before you break more stuff.
And no need for a mini starter unless you have headers or have more than stock compression
PinkyRingz
1997 - 2003 F150
38
Dec 3, 2019 04:42 PM
obscurity
15
Sep 10, 2015 04:09 PM
Michelle Pip
1997 - 2003 F150
Dec 3, 2012 12:21 PM
websthes
Apr 3, 2004 11:53 AM
birdmanlbexinc
Dec 1, 2003 11:00 PM
