Heater Fan
Old Dec 12, 2012 | 03:58 PM
  #46
Lil Red Sled's Avatar
Lil Red Sled
Originally Posted by Gary Lewis
Probably it then.
sure hope so. i got one coming from napa. $40
Old Dec 12, 2012 | 04:11 PM
  #47
Gary Lewis's Avatar
Gary Lewis
Not a bad price for a new motor. I'd bet it'll fix the problem.
Old Dec 12, 2012 | 07:18 PM
  #48
Lil Red Sled
Thanks for all your help guys! It was the fan. Brand new it actually was only 27$! Finally back to normal. Thanks again guys!!
Old Dec 12, 2012 | 08:42 PM
  #49
Gary Lewis's Avatar
Gary Lewis
Wow, that's cheap. Glad you got it going.
Old Dec 12, 2012 | 09:02 PM
  #50
Lil Red Sled
Sorry one more thing. My alt is pumpin out 14.9-15.1 volts. Makes everything flicker. Will I need a new alt too?
Old Dec 12, 2012 | 09:08 PM
  #51
Gary Lewis's Avatar
Gary Lewis
Probably. I'm guessing that in actuality you have a blown diode and you are getting un-rectified AC that is spiking the voltage up. Don't run it very long as you can damage other things. Oh, and the diodes are in the alternator.
Old Dec 12, 2012 | 09:18 PM
  #52
Lil Red Sled
Is it safe to drive 10 miles to work and replace it at work tomorrow?
Old Dec 12, 2012 | 09:29 PM
  #53
Gary Lewis's Avatar
Gary Lewis
Probably. There's no way to say for sure. But, don't rev it up. Keep the RPM down as it won't generate as much voltage at lower RPM. And, it wouldn't hurt to run several accessories like the blower and the headlights - unless the blower is running too fast or the headlights look too white. The load of the accessories will tend to keep the voltage down so it doesn't boil the battery or blow the various light bulbs.
And, it is possible that you will or have blown the new regulator with a bad alternator. They are frequently replaced in pairs. But, there's no need to just replace the regulator as it may well be good. Just check the voltage after you get the new alternator in.
And, btw, have the alternator tested at the parts store. I may be wrong.
Old Dec 12, 2012 | 09:33 PM
  #54
Lil Red Sled
Hopefully it didn't damage the regulator. Any way to test the reg?
Old Dec 12, 2012 | 09:41 PM
  #55
Lil Red Sled
I actually have another reg. il put it in with the alt just to be safe
Old Dec 12, 2012 | 09:52 PM
  #56
Gary Lewis's Avatar
Gary Lewis
I don't know if the parts stores can test the regulator, but they can the alternator. Good luck.
Old Dec 13, 2012 | 07:08 PM
  #57
Lil Red Sled
Alternator did the trick. Back to normal. Thanks again for the help and thanks for the quick replies!
Old Dec 13, 2012 | 07:15 PM
  #58
Gary Lewis's Avatar
Gary Lewis
Great! Glad to help. As for the quick replies, I have a computer in the shop and keep my email up on a 32" monitor that I can see from across the room. So, I check it every once in a while and that lets me answer quickly if it is a thread like yours where you are looking for quick answers.
Old Dec 13, 2012 | 08:07 PM
  #59
Lil Red Sled
That's awesome! I appreciate it. Il start keeping mine up on my tool box at work for now on.
Iron peddler
Nov 14, 2017 06:50 PM
ALBUQ F-1
54
Dec 1, 2011 11:28 PM
tomtoc
Oct 28, 2007 08:49 PM
shenders99
Jan 18, 2007 01:04 PM
Cephus
Aerostar
Jan 20, 2005 05:41 AM
