On the high setting, the current does not go through a resistor, so it should be whatever the alternator is putting out minus the resistance of the old factory wiring.
ok il check the voltage at the heater. is it possible that the two wires going to the heater fan are touching together making it smoke?
LOL. As I've said repeatedly on here, an iPhone takes good pictures but not of things up close like that. YUK! So, I'll take your word that it is bad, although I can't tell from the pic.
