Help with stuck shifter.
Old Dec 9, 2012 | 09:30 PM
mpgo4th's Avatar
mpgo4th
I have a 73 f100 with a straight six and a three speed on the column. The problem is the trucks been sitting for a few years and the shifters stuck. I can move it freely from second to third but it will not cross over to first and reverse. I got the truck running and pumped up the tires but now I can get it moved. It's going on my list of trucks to work on.
Old Dec 11, 2012 | 12:00 AM
VocaTexas's Avatar
VocaTexas
I would say you need to first determine where the problem actually is. Disconnect the shift levers from the transmission. If the levers on the tranny work as they should, make sure the column isn't binding up. It could be as simple as the shift linkages contacting each other because one is slightly bent. Having someone else operate the shifter while you watch the linkages would be a big help there.
eels67
Jun 7, 2019 04:35 PM
bighornjd
Oct 20, 2008 10:56 PM
confederate trucker
Feb 20, 2008 11:49 AM
Cracker289
Aug 31, 2004 01:15 AM
custom_truker
Mar 22, 2002 05:29 PM
